Time for Regular Service Message Reset Procedures Topic is solved
This topic is in the MVS Volvo Repair Database » Reset Volvo S60 Time for Regular Service message
Georgeandkira
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
Hello, "The timing is tricky"....You got that right brother! I just did mine; a 2002 with 105,300 miles, and the reset took on the 2nd try. It has always taken on the second try, even with my 1999. I could never feel confident enough to post instructions on this one. Thanks to all the posters who helped. Kira
smemon
Year and Model: S80 2003
Post by smemon »
I have an S-80 (2003) and the following worked for me...
1. Turn the ignition key to position I.
2. Ensure that the trip display is on T1 and shows some miles (not zero). Press and hold the T1 reset button and wait for the odometer to set to zero.
3. Turn the ignition key to position II, and watch the odometer.
4. When the previously displayed miles reappears, release the trip reset button.[/quote]
Thanks
Memon
blakey75
Year and Model: 2006
Post by blakey75 »
You can't reset service light with drivers door open!! If it wont reset first attempt stay in car, remove key from ignition, lock/unlock car, open/close drivers door then re attempt procedure. Hope this works for you.
300WinMag
Year and Model: 2006 S40
Post by 300WinMag »
I have a 2006 S40. The regular scheduled maint. light was on and could not figure out how to get it to shut off. This post was the answer.
Hold in the trip odometer reset,
turn the key through positions I and then II,
hold there and when the message goes away,
turn the key off.
endothrow
Year and Model: S60 T5 2002
Post by endothrow »
blakey75 wrote:You can't reset service light with drivers door open!! If it wont reset first attempt stay in car, remove key from ignition, lock/unlock car, open/close drivers door then re attempt procedure. Hope this works for you.
This was an important step on my S60. Second try with the door closed was successful!
2002 Volvo S60 T5- K&N, Royal Purple fluids, OBX DP, Iridium Spark
joeharvard
Year and Model: 2001 V70
Post by joeharvard »
guest wrote:I have an S-60 T5 (2002) and the following worked for me...
i have a 2001 V70 this worked for me with the doors closed and only after i started and ran the car. If i just turned the car on after the sequence the service message was still there. i actually had to start the car before the light would go out. hope this helps lower the frustration level with this rather necessary procedure - joe
Salvage1
Year and Model: V70 estate 2001
Post by Salvage1 »
brianf wrote:I got this off another Volvo forum and it works!!!!!!! The timing is the answer. I was trying the other methods but doing it too slowly check this out!!!!!!!!!
Here it is for all you guys who are proud Volvo owners s60 years 01-03 maybe newer cars too.
Resetting the Service reminder indicator (SRI), model years -2001
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The lamp remains lit for 120 seconds when the ignition is switched on.
Note! If the lamp flashes, it may be because one of the service parameters has not been programmed.
Proceed as follows to reset the service reminder indicator (SRI):
-Ignition position I
-Press and hold in the reset button for the trip odometer
-Ignition position II
-The service reminder indicator (SRI) starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
-Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded.
Note! If the trip meter reset button is not released within 5 seconds the indicator is not reset. However the indicator will stop flashing.
Resetting the service reminder indicator (SRI), model years 2002-
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The text message is displayed for 120 s each time the ignition is switched on.
-Ignition position II.
Note! Turn the key to position II within 2 seconds.
-Hold the reset button for the trip meter pressed in until the original value has been reset.
Note! For all vehicles from the 2003 model year a general yellow lamp will light when the reset button must be released.
-Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
-If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
will-sussex-uk
Year and Model: V70 D5 2002
Post by will-sussex-uk »
Another thanks , just did my 2002 V70.
sanda
Year and Model: XC90 2006
Post by sanda »
I just tried this on my XC90 2006 and it works. :D
cnshazen04
Year and Model: V70T 2001
Post by cnshazen04 »
I have a 2001 Volvo V70T All the warning lights in my instrument panel are on and wont shut off plus my window in the panel that tells you the codes that the car is having wont stop there a several that it says is urgent but when i connect a scanner to the obd2 it says there are no codes what is up with this thing?
