S70 Engine number
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
JRL
- Year and Model: Several
- Been thanked: 16 times
YEAR and VIN
I have 2000 S70 N/A. The number in the location indicated in the picture above reads 9186836 which is obviously much higher than the 1266128. However, it is so far above that it makes me wonder if it's proper. Are the numbers not incremental and some sort of date code?
The tag inside the drivers door indicates that the mfg date is 10/99.
Thanks for any insight.
jblackburn
You can also look on top of the timing belt cover. If you're looking for a timing belt/tensioner for your 2000 though I can go ahead and tell you, it is 100% the mechanical tensioner.
'98 S70 T5
JRL
2000s are all the same
- 499 Views
Last post by erikv11
- 860 Views
Last post by Ozark Lee
- 6747 Views
Last post by precopster
- 1349 Views
Last post by caj767314922
- 5619 Views
