98 v70 plugs question
triesandluth
- Year and Model: 1998 V70
how long would it take to trigger a CEL with inadequate plugs installed on my car? just bought it, drove it about ten miles then light hit. supposedly just had the plugs and wires changed the day before purchasing, and the wires a noticeably new. BTW, code is p0422.... hope i can find the problem without it being the cat....
triesandluth
oh and what type should be in there? i know that is real particular...
- Has thanked: 2864 times
- Been thanked: 1332 times
If I had a N/A Volvo I'd use the OEM triple prong Volvo plugs. You can get them from any Volvo dealer or at a discount from my sponsors (at top of the page).
10 minutes to a CE light is not out of the ordinary.
But first, just make sure the wires and plugs are installed correctly. So much of these types of problems are user error.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
P0422 is for the Cat, and if the car runs fine I think it's just a coincidence that you got the code after changing the plugs. If the car doesn't like the plugs, it will misfire and be noticeably bad to drive.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
triesandluth
then there is no chance for misfire. the car runs fine besides the approx 20 mpg with ac. wish it was better. code called for misfire, extreme vacuum leak, oil leaking through the rings or cat. hope its not the latter....
FlyingVolvo
If everything seems to run fine, I think the best thing to do is take a code reader and clear everything. Then see what pops up again and we can tackle each issue accordingly.
2023 V60 T8 PE
2023 V60 T8 PE
Volvo_240_Atari_2600
- Year and Model: 89 245 GL
triesandluth
I would definately go with the OEM Volvo three prongs as Mathew said.
I posted about plugs and the 98 v70 a year ago when I replaced my wife's plugs with Bosch Plattinums...
Car ran fine for a while then started to act up (misfire) allot.
The dealer carries them and not greatly expensive, or as Matthew said, I usually buy my parts at FCP Grotton and I think a pack of 5 is like $20 give or take.
Our cars do not like plugs that are not Volvo's for some strange reason.
Eric
Eric
triesandluth
thank you everyone. i will definitely get a reader and do as you said. then the fun begins. i'm still gonna check to see what kind of plugs are in it when i have a day off. again thanks all!
- 1722 Views
Last post by FLXC90
- 786 Views
Last post by Ozark Lee
- 811 Views
Last post by E Showell
- 1391 Views
Last post by theslashy
- 76 Replies
- 15010 Views
Last post by callahanoffroad
