Sun Roof Guide Rail?? Cracked
LakeFlambeau
Year and Model: 98 xc 06 xc 07 xc
Post by LakeFlambeau »
I have been having problems with my 1998 S70 Sedan's sunroof. Wind noise from not being properly
sealed when in position. So I removed the plastic covers last night, following all of the directions
that are out there for sun roof work. I was hoping for a loose screw, snugging it up and ready to go.
Unfortunately, I found a cracked part on the passenger side, on the piece that has the hinge in the front.
It is along the bottom part, not the top part where the front screw goes in. It cracked in the area of the
red circle. Hopefully the picture is readable. This is not a picture of my actual part, just a borrowed'
picture to show where crack is.
Anyway I talked to a Volvo dealer, showing him this picture and he came up with the part
being the Right Guide Rail, PN 9159880.
Does this sound right? If so, can you get at it from the top, or do you have to
remove the whole headliner to replace this part?
I have read through a lot of the posts on sunroof work, but unable to find an answer to this
question.
Thanks....
EDIT... Looks like picture is very hard to see. The crack is inside the yellow circle, not on the part that
swivels up, but along the part that stays straight when putting sunroof in vented position. Hope this makes sense.
EDIT 2 Posted a better picture
EDIT 3 Added some more pictures of actual boken piece. Top picture is the drivers non broken side.
The other pictures are of the broken passenger side. It seems like just the front piece could be replaced, if available.
Anybody have any ideas? The first thing I am going to try is the JB Weld thing also. Maybe drill some holes in each side
so I can get a little more area to grab.
Thanks
1998 XC, Now a 2nd 1998 XC 1998 S70
Previous
1997 850, 1992 740 Turbo Wagon. 1987 740 Turbo Wagon, 3 - 240's Various Years
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You should be able to get at it
peacock
Year and Model: S70 T5 SE 1998
Post by peacock »
mine is cracked in the same way on the drivers side. The REplacement cost for that part is 180$ the drive side is 220$. from the way the diagram looks i feel like u have too take off the head liner to replace that part. its the whole side rail you need.
1998 S70 T5 SE 214,001
1999 v70R 126,000
pkc303
Year and Model: 1995 T-5R Yellow
Been thanked: 3 times
Post by pkc303 »
Wow, can it not be welded, or something? Bummer.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
peacock
Post by peacock »
my first JB weld attempt didnt work. however i will tryin again this weekend with the sunroof fully closed. a good solution for now is too ride with the top popped.
1999 v70R 126,000
