I have been an avid reader of this website for many years and it has provided great benefits in my repairs so thanks to all. Also, I have never posted anything so I apologize in advance if this is the wrong place for this.
I recently replaced the struts on my 1998 Volvo S70 NA. Along with the struts (Bilstein TC) I also replaced the mounts and the spring seats with this :Volvo 850/S70/V70 Front Strut Mounts & Spring Seats Kit from FCPgroton. THe job went quite well except for a groaning noise which occurs when turning the steering wheel. I have traced the noise to the springs themselves which are rubbing against the inner side of the fender well on both sides. I have removed the shocks and made certain the springs were not installed upside down (which they were not). No matter what I do the rubbing noise (which is like a loud groaning) is still there. I have also verified that the springs rubbing against the fender well are the source of the noise by having someone turn the steering wheel while my hand is on the spring - its literally skips and stops against the fender well as the steering wheel is turned. Any clue as to what I have done wrong and what I can do to remove this problem? Thank you
Replaced struts now have groaning noise
guidingcenter
- Year and Model: XC70-2008
If the springs are indeed physically touching the inner fender, the upper mounts or springs themselves cannot be correctly installed/seated, or the parts are incorrect. If they are not actually touching then it could be anything from upper mounts to sway bar links not quite tight enough. Hard to say for sure, but I'd start with removing one of the struts and making sure you installed the mounts and seats exactly as the old ones came off, and the new parts are the same as the parts removed
guidingcenter
Thanks for the response. After replacing the struts and noticing the noise I removed the driver's side strut assembly and even replaced the spring mount again with a new one. I checked and rechecked everything again and re-installed the strut assembly...same problem. If your theory is correct then the only other part that could be wrong is the mount itself. However, these were, as I had mentioned, from FCPgroton and they were for this car and I checked them against the ones that I originally removed from the car and they looked identical. I did notice that the front end was riding noticiably higher than before the strut replacement but I have read here that this is typical for Bilsteins. Any other ideas? THanks
- Been thanked: 472 times
I wrote a DIY here:
https://www.matthewsvolvosite.com/forums ... 5&p=130339
I may be wrong but The spring is reversible, which means you can install it either way (anyone wants to chime in).
At each end of the spring, the end of the spring must be lined up with the proper spot on the:
- Spring Seat
- Strut Perch
I use:
- Spring Seat from XC90
- OEM (or Sachs) Mount.
- Spring Seat
- Strut Perch
I use:
guidingcenter
Thanks cn90 that write-up was one of the best ones I found and I indeed used it. After I noticed the rubbing and binding noise with the driver's side spring I took the strut assy out again and removed the spring and actually tried to reverse it. It didnt look like it wanted to play but I forced it anyway. This had no effect or actually made the problem worse. I have made doubly certain that the spring lines up with the proper spot on the spring seat and the strut perch. I am wondering if the whole problem is due to orientation of the spring seat or the strut perch and if reversing the struts (put the one on the passenger side on the drivers side etc) may solve the problem. On the other hand I do not think that would be possible with the strut mounts.
Take a few pictures and post them here so we can help.
- Neutral position
- When the Spring rubs against the liner etc.
PS: Did the wheel liner come off for some reasons and rub the spring?
- Neutral position
guidingcenter
Ok will do sometime later today. And no the wheel liner did not come off. The spring is clearly pressing against the fender well. Thanks for the help.
guidingcenter
Ok...so I am out to take pictures and I have my daughter turning the wheel while I snap away and I realize that there is NO RUBBING going on??!! On either side. Then I dig a bit deeper and find that the passenger side mount seems to be the source of the binding. As the steering wheel is turned the bearing binds and rotates causing the groaning noise. I have no idea what kind of brain anneurism produced what I wrote earlier. Bottom line is that the passenger side strut mount seems to be bad. Does this make more sense than before? Needless to say pictures are not really going to help since there is nothing to see now that I have really found the source of the noise. But if it werent for the request I would have never found it. Thanks again cn90.
I thought you install new Strut Mount (this is the part with the bearing in it)?
The problem with FCP Groton is they carry both quality parts (Bilstein) and craps (such as Hamburg Technic etc.).
Perhaps the Strut Mount you bought was made in China etc.
FYI, as in my write-up, I used:
- Bistein TC Struts
- XC90 Volvo OEM Spring Seat
- Strut Mount by Sachs-Boge (which is OEM).
This is a problem when doing strut work: it is alot of work, do your research ahead so you don't end up with issues like this.
- Bistein TC Struts
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
For the most part, on these cars, where you think you are saving money with aftermarket parts, you will only end up costing yourself more in parts/work in the long run. Both I and many others that own these cars have found that out the hard way.
'98 S70 T5
2016 Chevy Cruze Premier
