replacing Pedal Position Sensor
sjr2531
Year and Model: 1998 saffron V70R
Post by sjr2531 »
When i replace this part guy's, will i need to take it to the dealer for reprogramming? it's for my 2002 s60
2002 s60 T5 manual 98,000 miles
(R.I.P 12-26-2010 112,000 miles)
1998 Saffron V70 R 109,000 miles
"My Precious"
igel513
Year and Model: 2003 S60 T5
Post by igel513 »
Just wondering, where is this sensor located at.
sjr2531
Post by sjr2531 »
It's attached to the actual pedal with a plug in and a couple of bolts. the part i saw was $528.00 (us) and was the whole setup with pedal and everything. my Volvo popped generic code p2127 and displayed engine system service required light. car went into "safe mode"/ " limp mode" and limited my speed and rpm to 2-3k and basically 60mph. First real issue in the first 100k miles other than the alternator @ 73k miles. This has been an intermittent issue occurring twice and returning back to normal after parking and letting it sit over night. Still, there is something wrong.
"My Precious"
jruberto
Year and Model: 2001 V70 T5
Post by jruberto »
Just a thought, this sounds like it might be the failing ETM that may be covered under extended (10 year / 200,000 miles) warranty, see the ETM forum here... https://www.matthewsvolvosite.com/forums ... php?t=5694
cheers, j
2001 V70 T5
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
the pedal position sensor is attached to the brake booster in the engine bay.
Replacing this sensor does not require software download by the dealer
smarzig
Year and Model: S60T 02
Post by smarzig »
hey did replacing your sensor make the issue go away? I'm having the same problem. A shop changed my serp belt ac comp and pulleys, but no my s60t 02 has no real pickup and will slowly crawl to 60+ mph but i have no pickup. Driving around town its ok.
- Smarzig
02 S60T 17"rims
jclipper7
Year and Model: '03 V70 2.4T
Post by jclipper7 »
If you haven't bought this part yet and still need it the same part is available at rockauto.com for $114.79 (it's undre fuel/air topic).
smarzig
Post by smarzig »
are there any directions or walk-throughs for replacing the pedal position sensor on my s60T '02?
- Smarzig
02 S60T 17"rims
smarzig
Post by smarzig »
For this issue mine wound up being the pedal sensor that the dealer nailed down and fixed.
I finally have pickup. Weird that it went after my belt snapped and I had it replaced along w. the ac comp/pulley.... :roll:
- Smarzig
02 S60T 17"rims
