1998 Volvo S70, Display lights, TRACS OFF and ABS
camilla1010
- Year and Model: 1998 Volvo S70
My 1998 Volvo S70 has the TRACS OFF light and ABS light coming off and on. What could be the possible problem and solution to this problem? Could it possibly be the master brake cylinder?
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
99% chance your ABS module is dead. Don't buy a new one (BIG $$$)or have a shop do it, they'll charge you way too much. You can have it rebuilt at http://www.modulemaster.com/en/index.php for $100. Before I knew all about repairs and fixes for these cars, we had our module rebuilt at a local shop... $600.
But now I know!
If you're not comfortable messing with it, just have a mechanic "remove the ABS module" and then send it off yourself to be rebuilt, and when you get it back, you can have your mechanic re-install it. It's okay to drive for a little ways with the module out.
Welcome to the forums by the way!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
camilla1010
Thanks for the advice and the welcome Ed!!!
Can you explain how to remove the ABS module? I've figured out how to change the O2 sensors (which is relatively easy considering they charge so much $$ for something so similar to a spark plug). Also, this sensor has been coming off and on for awhile now, should I be concerned?
FlyingVolvo
The website for Module Masters explains how to remove the module, here it is: http://www.modulemaster.com/en/Volvo/S70_info.php I've never done it, but if you're willing to give it a shot yourself, there are definitely many other people here who can give you some pointers.
What sensors are you talking about, the O2 or the ABS/TRACS? When the ABS/TRACS lights are on, basically it just means you don't have Anti-Lock Brakes. It's still safe to drive, although in a panic stop or on snow/ice there may be wheel lockup.
2023 V60 T8 PE
2023 V60 T8 PE
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Here's another rebuild site with a TON of using info,
including some pretty good removal instructions.
http://home.earthlink.net/~vicrocha/
These guys rebuilt my module over 4 years ago and
I have had zero problems since.
I would add a couple suggestions.
Layout a shop rag or an old towel on the transmission, just below the module.
If you drop a screw, you won't spend all day looking for it as the towel will catch it.
(Ask me How I Know!
I also had a gravity problem with my E-5 socket. It's a tight spot and even using an angle
head 1/4" ratchet, I lost the socket a few times. The towel didn't catch that as well, so I
taped a dental floss "leash" to my socket and it was simple to recover if it fell into the
darkness of the engine compartment.
(Ask me How I Know!
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
We rebuilt our own following the instructions on this site. You can do it, if you can solder.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
- 22 Replies
- 6193 Views
Last post by hausmeister
- 1824 Views
Last post by Matty Moo
- 1802 Views
Last post by CDoore54
- 2175 Views
Last post by rguzz
- 12 Replies
- 1889 Views
