how big a mess is the heater core
mjbrox
Year and Model: 1999 V70
Post by mjbrox »
In the past week, i have had to add coolant to the 99 V70 twice.
I just pulled back the carpet and it had some sticky fluid on it.
I am guessing, I need a new heater core.
My question at this point is. Will I have to pull out all the padding to let it dry? is that a huge pain in the butt?
mjbrox
Post by mjbrox »
for what it is worth,
I am a pro at pulling carpets : )
C@lvin
Year and Model:
Post by C@lvin »
I spilled quite a bit of coolant when I changed my S70 heater core a couple of years ago. It took what seemed like months for it to dry out. the padding underneath the carpet was quite soaked as well. If you are comfortable pulling the carpet and padding and have a way to clean and dry it, then based upon my experience, I'd say go for it.
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
mjbrox
Post by mjbrox »
C@lvin wrote:I spilled quite a bit of coolant when I changed my S70 heater core a couple of years ago. It took what seemed like months for it to dry out. the padding underneath the carpet was quite soaked as well. If you are comfortable pulling the carpet and padding and have a way to clean and dry it, then based upon my experience, I'd say go for it.
with enought beer and time anything is possible
I just do nto seem to have time
I was just reading about this PCV crap and I can not belive i have to remove the manafold to get to it .
who comes up with this crap?
mjbrox
Post by mjbrox »
Heater core done.
My carpets and padding where already soaked. when I pulled the line out of the heater core I dumped a lot of coolant. So I stuck my finger in the hole, called my wife and she brought me a trash bag to fill up. That actually worked pretty well.
I did not feel like pulling out my seats, dash etc etc. So i cut out some large sections of padding and propped the rest up with screwdrivers. I then just left the doors open for a couple days. It did not dry out 100%, but i needed the car back on the road, so I closed her back up.
My acura MDX is down, so my wife is driving the volvo and I am driving the Rover. She had not complained, so I guesst he volvo is doing ok now.
xjflexer
Year and Model: '96 850 R Wagon
Post by xjflexer »
mjbrox wrote:I was just reading about this PCV crap and I can not belive i have to remove the manafold to get to it .
I find this comment quite amusing at the moment as I recently posted about how much I love working on these cars because everything is so easy. The intake is cake to remove on this car. Try removing the intake manifold on a '95 LS400 because the starter took a crap. You need a 36" extension to reach the stater bolts, and they are TIGHT and OLD!!! Strip the head, and your day just got REALLY bad.
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 18 times
Been thanked: 33 times
Post by ignatz »
I drained and filled the cooling system 3 times with distilled water before doing the job. After the final drain, I replaced the heater core without clamping the hoses in the engine compartment. I only got what was in the heater core and nothing else. I was prepared for a big flood...but nothing more than the heater core.
I did everything I could to keep antifreeze out of the car's interior, and did good!
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
mjbrox
Post by mjbrox »
I already had coolant on the carpet from when it was leaking.
my pad was still a bit wet when I put it back together
