Horn will not stop blowing
volvo9485t
- Year and Model: 1994
After hitting my steering wheel(in the middle) out frustration
, my horn will not stop blowing. I had to disconnect the horn cables, from underneath the hood in order for the horn to stop blowing.... Any advice is welcomed, because now after hooking the horn cables back up to the horn, and removeing the fuse for the horn, I've created another problem, my windshield wipers will not work.....Thanks in advance!!!!!
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Been there done that...so has half of the forum here. You broke the plastic tabs in the steering wheel. This was one of my first DIY projects. Take a look at this stuff:
-> http://volvoforums.com/forum/showthread.php?t=17791
-> https://www.matthewsvolvosite.com/tips.php <- Scroll down a bit
When my horn contacts busted, I upgraded to a leather steering wheel that I got from a local Volvo/VW salvage yard. (Still had to fix the the horn contacts in it.) The leather wheel has been much nicer to drive with than my original.
I replaced the contacts using screws, nuts, nylon washers and heat shrink tubing around the screw that I got at Lowe's Home Improvement.
1998 S70, 5 speed manual, 146k, wife's car
1997 850 Wagon, 5 speed manual, 185k, son's car
1996 850 5 speed manual, 220k
1985 MB 300D 268k, running on B20 biodiesel
1983 MB 300D 240k , converted to vegetable oil
1981 VW Vanagon 184k
- 4105 Views
Last post by MazdaDude
- 1625 Views
Last post by crimsonv70
- 4966 Views
Last post by Amk20155
- 13 Replies
- 5002 Views
Last post by cliffordhubbard
- 1408 Views
Last post by Joffwillson
