Hello All,
I have a 97 850 non turbo and have been getting the P0446 DTC for Evap system malfunction. I have actually replaced the gas cap and purge valve to see if this takes care of the problem. I was utilizing some of the posts here in regards which seemed to be common problems. I should probably have it taken in to a shop for analysis, but an trying to figure it out myself if possible. Any advice out there as too which steps I might take to resolve this?
Thanks,
Jay
Evap P0446 problem
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I would check the hoses that go to the charcoal canister in the engine compartment and the roll over valve (near the fuel filter).
JRL
- Year and Model: Several
- Been thanked: 16 times
If this one has a J hose look at that.
(Some do, some don't, I don't know exactly which models use this system)
It's a small hose near the fuel fill shaped (obviously) like a "J"
Sort of a small PIA hose to get at and repair, but this is one of the 2-3 problem areas that throw that code.
These do go bad and if cracked will set that code
yojaywuzup
- Year and Model: 850 1997
I will check all these out and get back with feedback.
Thanks
Thanks
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Also take a look at the hose running from the TB to the purge valve.
yojaywuzup
Sorry about the delays guys but work was a little crazy this week. So I did some looking around and I have submitted some pics for your opinions. I had just replaced the hose going from the TB and the purge valve and my prob did not change. I went looking for the "J" valve and from underneath it seemed to look like piping and was pretty solid. What I did find is what I believ is the rollover valve and the hose going to the tank side of it has a crack at the end ( circled in pic) could this be my culprit and if so could this be spliced or should the hose hose be replaced and lastly if it is the latter about how much hose do you think it would take ( I'm really not sure).
Thanks again for all the advice!
Jay
Jay
yojaywuzup
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
I think you found it.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
yojaywuzup
I think I have as well. Is this just regular vacuum tubing or should I look for anything in particular?
- pkc303
I think that is just regular fuel line. I'd check the diameter, bring a piece to the parts store. Have them match it up, as fuel line. Better safe than sorry.
- 11 Replies
- 2085 Views
Last post by marcus
- 1828 Views
Last post by BrianV70
- 16 Replies
- 1055 Views
Last post by Brickbox8398
- 576 Views
Last post by Raul_duke
- 740 Views
Last post by Ozark Lee
