740 Front Rotors
arbop
Year and Model: 2004 V70
Post by arbop »
Attempting to replace the front rotors on my 740 GL, non-ABS. Have tried two different sets of rotors, from two different vendors, (Auto Zone and Advanced Auto), with the same problem. The part of the rotor that fits over the front hub seems to be too small, maybe .010 to .015 of an inch. To clarify, nothing to do with the lug spacing, but specifically the rotor over the wheel hub. The front hub itself seems to be an original item, and the rotors I took off came off quite easily. Might my problem be caused by where I am buying my parts? Anyone have a suggestion as to the cause of my problem, and where to get some rotors that will fit? Thank you
Current: 2004 V70
Prev: 73 1800ES, 76 240DL, 79 245 manual, 78 242GT, 81 245 GLT, 87 745 Turbo, 97 850 T-5, 89 745 manual wagon, 1992 240, (this one saved my life!). 2004 V70 2.5T. Whew!
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
What are the brands and part numbers of the rotors. They may have given you the wrong rotors. I find that the people who work at these two stores are about as helpful as a cat or dog at finding the parts that you need. Actully, the girls who work in my local Advance Auto and Autozone are more helpful than the guys. Matbe this is because the guys always try to tell you what you need instead of asking you what you need. If you can look the parts up on their sites yourself then you can check the part numbers. Your 91 740 non-ABS should have Girling dual piston calipers and 287mm (11.3 inch) rotors.
I took the time to look up the part numbers for you.
Advance Auto Parts:
Wearever brand: YH141651
Autozone:
Duralast brand: 3488
These are the only rotors listed for your 1991 740 w/o ABS.
1988 Volvo 760 Turbo Wagon
arbop
Post by arbop »
Have returned both sets, no doubt Chinese-made. probably by child labor. You are correct as to the Girling rotors, but I believe it calls out a diameter of ~10.25 inches, and that is from my memory, so no promises.
Current: 2004 V70
lummert
Post by lummert »
It must be too hot in here. The numbers that I gave you are for a 91 740 w/o ABS, not an 89 740 GL w/o ABS. The correct numbers are:
Advance Auto Parts: YH141421
Autozone: 3487
The numbers that I gave you would work with ABS.
lummert
Post by lummert »
The diameter is listed as 11.25 inches for 89 740 GL with or without ABS, they just use different rotors.
arbop
Post by arbop »
Just checked the Advance Auto receipt, the part # is/was YH141531
Any idea what that is supposed to fit?
If I go there and ask for the YH141421, pretty confident it will fit?
Thanks for all the help, really appreciated!
Current: 2004 V70
lummert
Post by lummert »
I tried to find what that Advance YH141531 number fit. I found cross reference to a 1989 Volvo 740 with 14 inch wheels. As far as the YH141421 fitting, I now am not sure. When I looked up these rotors on NAPA site they list 262mm, 280mm and 287mm rotors for the front. The 280mm is for models starting with 1991 with ABS and single piston calipers. The 287mm is for 740/760 models with ABS with dual piston calipers, and 1991 740 w/o ABS with dual piston calipers.
edit: I went back to Advance Auto Parts website and looked up an 89 Volvo 740 GL. The front rotors are listed as YH141531 (10.25in. diameter for no/ ABS) and YH141421 (11.25in. diameter w/ ABS)
Autozone lists for 89 740GL: 3487 (262.5mm for no/ABS) and 3488 (287mm w/ ABS).
arbop
Post by arbop »
Amazing, now I am totally confused! 1989, GL, 15 inch steel wheels, no ABS, single piston caliper. Care to venture a guess? Starting to look as if it may be order the part # you provided, and use calipers before I try to install them. I do know that the YH141531 does not fit.
Current: 2004 V70
lummert
Post by lummert »
If you have a NAPA in your area they have prices that are just as good as the two stores you mentioned. Here is how they compare for the 262.5mm rotors:
Advance Auto Parts: $32.99
Autozone: $32.99
NAPA has several brands available:
NAPA Premium: $27.37
NAPA Ultra Premium: $45.08
Brembo: $65.59
Ultra-8 by Altrom $33.09
They also sell Zimmerman rotors.
I have used several parts on my 88 765 from the Altrom parts line at NAPA. They have always been the same parts suppliers as the OE manufacturer.
waydar
Year and Model: 240 1984, 1992, 1993
Post by waydar »
Are you sure about your car having ABS? As far as I know, the single piston caliper is for ABS cars only. The non ABS cars I have worked with all had 2 piston calipers because of the dual diagonal braking system.
