94 850 na engine is caked with sludge, oil from formerly clogged PCV, and general road grime. What would be a good degreaser that is safe for the engine?
Matt
Nasty Engine
volvo850black
- Year and Model: volvo 850 1994
MattC 94 854 NA and 96 855 turbo
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
I picked up a can of cheap spray-on stuff at AutoZone and it did a great job. If it's really nasty, you may have to do it twice. I did it once, but used a toothbrush to scrub all the nooks & crannys and all the heavy build-up. It might be a good idea to cover the driveway with some soapy water under the car before you do this - it'll look like an oil spill when you hose it off!
To make it really look good afterwards, spray it down with a 50/50 mix of water & Armor All and let it air dry. Looks pretty sweet, especially the plastic and rubber.
I've also used A.A. sprayed onto a rag to scrub the rubber & plastic under the hood. It helps to remove the dirt/dust/oil buildup really well.
A few other things you can do to make it look even better:
- Paint the sparkplug cover with high-temp engine paint.
- Peel off the sealant from the fuel rail and engine block - The engine takes a little more effort so I'm still working on it, as you can see.
- Rub the aluminum heatshield on the firewall with a dry, clean rag to polish it up nicely.
Kind of hard to tell how improved it looks from these pics, but trust me - it sure doesn't look 14 years old!
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- Has thanked: 2857 times
- Been thanked: 1332 times
Brake cleaner will take off ugly gunk, but in small patches, so it's not suitable for an "all over" application. If you're not familiar with it, it's a spray can product, is nasty to breathe, evaporates quickly, and is hyper flammable so wait until the engine has cooled after a drive, and certainly don't use it while idling.
I use it with one of those tiny red straw attachments to blast nooks n crannies. Watch out, it will come back at you. Wear eye protection and gloves.
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
I've got one of our 850's with years of leaking oil (previous owner) from a clogged pvc, (fixed now) along with road grit that is forming a protective barrier under the car, and all of the components. I've taken it to a spray car wash, and tried to get under the car with it ramps. Only moderate success. I've tried the auto parts spray, let it sit, and wash it off. Both methods are pretty good, but are still leaving some residue. Now, I'm going to try what they use down here in the Gulf of Mexico area to clean up the BP tar, Dawn detergent. my neighbor swears by it.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
I have been using a product called "Super Clean" for cleaning engines, tires, motorcycles, you name it. It comes in a purple gallon jug and available at many of your big box stores. I usually cut it 100% with water and it will still cut most any greasy mess you could come up with.
I must add that the active ingredient in Super Clean is sodium hydroxide (lye) so be careful. Also please do not clean engines or parts in your driveway if you live in an area that has paved streets, curbs and storm drains. These go directly to the nearest stream, creek, river, etc. If you live within city limits, there are strict regulations and stiff fines for discharging greasy/oily washwater to the storm system. The best place to get something greasy really clean would be the coin operated car wash, they are connected to the sewer and you can take advantage of the high pressure.
OK, I'm off my soap box (no pun intended)
mindshadow
- Year and Model: none
Stupid question: When you apply these products and hose them off do you have to use a lower pressure water source (e.g. a water hose) or is the high-pressure hose at the car wash fine? I ask because I can see a high-pressure hose breaking some of those older rubber hoses.
vjaneczko
I'd avoid those high pressure hoses for that very fact - too much pressure coming out and breaking something. If you use a regular garden hose with a spray attachment, you should be OK. If you have to use a car wash hose, use the one with the fine mist setting; I'd think that may push enough water to rinse everything off.
2006 S60R - For ME!
2006 S60R - For ME!
- okihiro
- Year and Model: 1991/240..2014/xc60r
sorry im new to this, but are you all referring to spraying the engine compartment with water? is it ok to do that? or are there certain precautions needed to not get water into parts that might be allergic to water?
vjaneczko
If you head to AutoZone and pickup a can of engine cleaner, it'll tell you to cover the distributor, alternator, etc. with a plastic bag before spraying it down. Once it sets for 10 minutes, you hose it off - but I'd make sure you don't use a high pressure nozzle. Just a regular garden hose with a spray attachment will do fine.
2006 S60R - For ME!
2006 S60R - For ME!
Volvos rock3
- Year and Model: v70xc, 2002
yes, +1 for the garden hose and super clean/purple power. long time ago when I worked as a detailer at various dealreships, and to this day I will have the car running when it is time for the hose (dries it out quicker, leave it running when your done for a few minutes with the hood latched but not closed and a quick spin around the block) and don't spray to hard in anyone spot, let the cleaner do the work before you spray it with the hose.
1996 850 GLT sdn (deceased)
2002 V70XC 118k
2009 S80 3.2 37k
1998 Chevrolet K1500 84k
1965 Pontiac Lemans convt
2009 Chevrolet Tahoe PPV 2x (work)
2002 V70XC 118k
2009 S80 3.2 37k
