Just curious if anyone can lineup some primary suspects in my hunt for a vacuum leak on my 1996 960 wagon which is making my AC go away when accelerating. I really want to minimize getting into the dash as much as possible. Any likely places that are not too difficult to get to? The 960 is new to me so I am not familiar with the climate control vacuum system.
Thanks very much,
Jim Lee
Searching for 960 vacuum leak(s?)
In the engine bay, running into the firewall should be two vacuum lines if I remember correctly. On my 760 these run into two separate check valves, and then run into a vacuum tee which connects to the intake. I have the same problem with my vents, but it's very intermittent... still haven't found the culprit. Anyway, sometimes the check valves that I just mentioned can go sour and cause your vents to slam shut on acceleration; which I'm guessing is what you mean by the AC goes away?
Thanks,
Darrell
Thanks,
Darrell
sasjzl
- Year and Model: 960, 1996
My mechanic is describing the problem to me and all I know right now is that the AC only works at idle and when you accelerate and change the vacuum situation the AC stops blowing. We did not go into it in detail but my assumption right now is that a climate control door is either not opening or closing when the vacuum changes. I am going to have them check whatever the usual suspects are and then if they cannot find the culprit I am going to continue the hunt. What I hear is that it can be a long hunt and I cannot pay for it at $xx per hour. Best case is that they find a check valve or diaphragm in a reasonable time.
Thanks very much,
Jim Lee
Thanks very much,
Jim Lee
I just fixed this problem for my 97' 960. What happened is that the vacuum line connecting to the vacuum tube on the firewall on the engine bay side got lose over the years and under the hot Texas weather. I pushed the vacuum line toward the vacuum tube to make it tightly connected. Now the AC control can change the vent position and cold air flows.
jimmy57
- Been thanked: 322 times
The firewall is the metal panel at back of engine compartment that makes the forward wall of passenger compartment. The vacuum lines for climate system come from a multiple vacuum port fitting on back lower intake (below and rear of throttle) and run across the firewall right about top of engine level and go to connections on the RH side next to the small and large aluminum lines that are the a/c pipes that run into the car.
- 15 Replies
- 2748 Views
Last post by volvofornia
- 1237 Views
Last post by 93Regina
- 2213 Views
Last post by DonVanhugenstein
- 1035 Views
Last post by MadeInJapan
- 14 Replies
- 1520 Views
Last post by vtl
