1994 850 turbo wagon 152K.
The rear washer quit.
I followed posts to diagnose. The posts I found with the VADIS PDF for the wiper/washer systems was enormously helpful, as was the information about the filter.
The pump is good, and the filter is passing fluid.
I expected the problem to be the pressure relief valve.
Instead, what I have found is that the long hose going from the distribution side (rear) of the filter to the pressure relief valve seems to be clogged.
I had a wire that was just stiff and just flexible enough to pass through the hose, but it's unfortunately just big enough in diameter that it gets stopped at any point in the hose where it's held in place by the metal clip-on retainers. I went as far as I could in each direction without taking off the clipped in interior panels.
So, I am looking at this and it appears that the hose can be removed/replaced if I remove enough interior parts (which, judging from the tailgate, seem to be held in place with self-destructive plastic clips).
It's a big job, and I am understanding why most people seem to quit easily when the rear washer stops working.
I may be up to the challenge. It seems like it will look possible once i get the interior apart (ugh).
It has occurred to me to ask for wisdom.
Does anyone have experience with this?
It's mysterious to me why the hose carrying filtered fluids would suddenly become clogged.
I figured that I would go ahead and replace the hose as long as I had everything apart. From what I can see, the tricky part is inside the tailgate window frame where it routes from the hinge through the window frame. This I can do with some sort of chaser.
As far as parts go, is this just plain hose, or is this a Volvo part?
The hose is in good shape externally, so it's high-quality stuff.
As far as taking off the interior parts, is it just the clips that I will break, of do I risk something more heinous?
I would like to do this project and have everything working on the car for one more moment in time.
Dave
850 rear washer (hose clogged)
dstthomas
- Year and Model: 855/Turbo SW 1994
I have made a discovery in preparing to replace the hose I mentioned.
Upon removing the black plastic cover that protects the hose as it runs along the right hand side hinge, I discovered an additional relief valve, or anti-syphon valve, or whatever these things are.
I wager this is the problem, and will replace both of these valves.
meine39
- Year and Model: 1995 850 GLT Wagon
Check the bottom of the wheel well where the spare tire is stored for any signs of water - the tubing for my rear washer had disconnected at a coupling in the hose located under the carpeted load floor, and the washer fluid was pumping into the wheel well. The carpeted floor panel can be removed (right side of cargo area) to access the line and reconnect the tubing.
1995 855 GLT 190K NA Auto
1998 BMW 528im 137K
2000 Toyota Camry 78K
2010 GMC Acadia 57K
1998 BMW 528im 137K
2010 GMC Acadia 57K
dstthomas
Thanks meine39 - everything looks good as far as the hoses connecting into the filter.
I am certain that the 2nd valve is the culprit. There are forensic signs of washer spray collected all around the valve.
I'll replace both of these valves. The VADIS doc showed the standard relief/syphon valve (near the nozzle). Nothing prepared me to look under the black cover for a second valve.
It'll take me a while to get the parts, then the re-install should take a few jiffies.
I'll snap a picture or two for thecheat, which will give me a bit of practice with that.
dstthomas
I apologize for starting a new thread instead of posting my original problem in:
Volvo 850 Wagon Rear Window Washer
I thought I had a different enough situation, but it turns out not really.
@thecheat:
It sounds like you are describing the washer supply line and the in-line filter.
@thecheat:
thecheat
- Year and Model: 1996 850 Turbo Wagon
Thanks for that link, the PDF in it gave me what I need. Will try to clean out the valve behind the nozzle later.dstthomas wrote:I apologize for starting a new thread instead of posting my original problem in:
@thecheat:
Also, the tube and tank I refer to is much larger than the washer plumbing. The tube is about 3/4" diameter , goes toward the front of the car and ends in a soft blow molded tank that press fits into an exit hole in the floor. I suppose it is a drain fir the door sills or something.
dstthomas
Since a picture is worth a thousand words...
1 Having removed the moulding for the liftgate, here is the valve I was expecting after studying the VADIS PDF posted by MadeInJapan in "Volvo 850 Wagon Rear Window Washer":
2 The hose feeds along the right side hinge:
3 The black plastic cover snaps off easily to reveal a surprise...:
4 The Fluid stains tell the tale:
- 588 Views
Last post by 93Regina
- 15 Replies
- 8927 Views
Last post by volvolugnut
- 36 Replies
- 25046 Views
Last post by StickyPocket
- 757 Views
Last post by Sommerfeldt
- 1574 Views
Last post by Roger_850T
