I have an intermittent CEL code P0300, it tends to go away when it's warm out. I've taken it to the local Volvo shop 3 times. He can't find the reason for the cel. It's missing on cylinders 4&5. I've had new plugs,rotor,cap, wires, coil they all check out the right voltage.
I did a pcv job and tune up before this problem started, so I guessing it's something I did wrong.
Ideas welcome P0300
- Year and Model: Many Volvos
- Been thanked: 76 times
It is a bit unusual to have a P0300 by itself. It is a multiple misfire code that is normally accompanied by the codes that identify the cylinders that are misfiring.
What kind of spark plugs are you using and did you gap them to 0.028?
Since you serviced the PCV just before the problem cropped up I think I would check the intake manifold gasket to make sure it is sealed.
- 4626 Views
Last post by xHeart
- 20 Replies
- 5308 Views
Last post by clifford06
- 13 Replies
- 3547 Views
Last post by shiloh51933
- 3993 Views
Last post by matthew1
- 11 Replies
- 2087 Views
Last post by YV1LW
