Hi
I have a 1994 850. The door open chime won't turn off at all and the interior lights stopped working. The ding,ding,ding sound is driving me insane. How do I get it to turn off and what does it have to do with the interior lights?
94 850 door chime wont turn off
dianehb131
- Year and Model: 850 1994
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I hate that chime.
Rip out this relay from the panel under the dash kick panel. It's on the bottom row:
https://www.matthewsvolvosite.com/forums ... 2&p=130610
Chances are, one of your door switches is no longer working. It can sometimes be hard to track down which it is, though, especially as they are inside the doors themselves.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
These cars don't have one for the headlights, as they turn off when the car turns off. Now if you leave the parking lights on...
They're all controlled through that. I don't seem to recall a seatbelt chime either, just the overhead reminder lights which are also controlled by the relay.
If yours is missing/broken and you'd like to have it, I can send you mine...I sure don't want it
'98 S70 T5
thecheat
- Year and Model: 1996 850 Turbo Wagon
Huh... My lights go on in the overhead console but no noise. No big deal. I do recall the parking lights staying on with the key off... Too bad there isn't an alarm for that.jablackburn wrote:These cars don't have one for the headlights, as they turn off when the car turns off. Now if you leave the parking lights on...
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
I was responding to the OP.thecheat wrote:All the lights work... I'm not losing any sleep over the chime... It cooed be the chime itself i suppose.BEJinFbk wrote:Sounds like you blew the dome light fuse.
Since you appear to have a different problem,
you should probably start own thread.
- BEJinFbk
Continuing with the issue at hand, if the fuses check out,dianehb131 wrote:Hi
you may also have a bad "door closed "switch. That not unusual with these cars.
The hard part is that the switch is built into the door latch and to fix the switch,
you'll probably need a new latch assembly. Hopefully, it's just a fuse.
This issue of the interior dome lights stopped working and the door chimes keep going is upon me. I went to the gas station, filled up, jumped in and the ding, ding has not stopped since.
I checked the fuse box and saw where the fuse for that circuit was blown. When I replaced it everything came back, until I started the car and it blew the fuse again. Electrical troubleshooting is outside my comfort zone, but I am willing to do it. Can someone point me in the right direction? I am confident it may have something to do with the drivers side door but it is there I get stumped. Well, that and the $200+ price for a new door latch assembly.
Is there a way to get the dome lights working again? I really don't care about the door chime.
