Home Made Short Ram Intake
This topic is in the MVS Volvo Repair Database » Short Ram Intake
georgeleedom
Year and Model: S70 GLT 1999
Post by georgeleedom »
I toyed with the idea of trying the dryer hose, funnel system that Matt posted, but the clearance getting up past the battery is tight in my S70. And once you remove the weather guard from the stock intake, which is a pretty straight shot, I don't know if it would make all that much difference.
I did want to put on a performance air intake. The drop-in K&N filter that fits in the stock air box is a reasonable option, but I wanted the look and especially the sound of the SRI for my mid-life crisis machine. The IPD and Eurosport kits run around $150. I bought a K&N filter and fashioned the box out of a $13 piece of aluminum and some 1/2" pipe insulation. You can judge from the photos, but I think it came out pretty nice for $60. I haven't had the chance to measure any mpg increase, but that sound I wanted is definitely there.
I recommend making a cardboard template. I Wasted a lot of time fitting, cutting, re-fitting, re-cutting. Although time fiddling with my Volvo is never really wasted.
'99 S70 GLT:
16T turbo, 465cc injectors, iPd tune, iPd coils, Walbro 255LHP fuel pump, Chrysler 4bar regulator, H&R Springs, iPd anti-sway bars, ceramic brakes, strut brace, B&M tranny cooler, Samco hoses, K&N filter, 3"Borla exhaust.
thecheat
Year and Model: 1996 850 Turbo Wagon
Post by thecheat »
Very slick!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Very nice! You should take a video of the sound. I've always wanted mine to sound as cool and throaty as the NA engines :mrgreen:
'98 S70 T5
2016 Chevy Cruze Premier
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
That came out awesome!! I tried to make one for my 850 T5 back in the day and failed miserably.
georgeleedom
jablackburn wrote:Very nice! You should take a video of the sound. I've always wanted mine to sound as cool and throaty as the NA engines :mrgreen:
The sound is more high-pitched as the turbo is spooling up; kind of like whistling through your teeth while humming.
'99 S70 GLT:
nightc1
Year and Model: 99'V70 Base 140K+Mi
Post by nightc1 »
Wow that looks pretty nice.
Now I need to hear it :wink:
thecheat
Post by thecheat »
Make it sound like a vw 1.8 turbo with a cai and reversed Forge valve and I'm sold. Oh yeah, and figure out how to drop in a manual transmission and LSD for $20. :D
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Nice, George. Thanks for sharing. Good tip on the template suggestion.
Also -> Amazon link
mindshadow
Year and Model: none
Post by mindshadow »
Stupid question:
If the point of a short ram intake is to deliver more air at a better temperature wouldn't having the intake behind the battery actually introduce more hot air than the stock intake? Or is your concern here more about the volume of air entering the engine?
georgeleedom
actually, you're using the battery as one side of the "box" that surrounds the intake. Cold air is being forced in from the grille through the stock tube that goes from the radiator to the air box. The most important aspect is sheilding it from the engine heat itself. It's an exact copy of the unit sold by IPD. If you go to their site they have a video about how it works. It's called a ram intake as opposed to a cold air intake, because it doesn't drop the ambient tremperature that much over stock. It does draw a lot more air into the turbo, though. I also removed the weather guard from in front of the intake tube at the grille. This for more air and I'm really not concerned about water or debris being drawn into the box. It would be too dense to be pulled into the filter. I hope this answer helps.
'99 S70 GLT:
