Thanks—
Need help ID'ing where vacuum line plugs in
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
After putting my airbox, battery, cooling fan back in (replaced alternator, radiator hose, heater core), I got everything reconnected and it started right away BUT I have one dangling white plastic line about 10" long with an elbow on the loose end. It comes off the vacuum tree (top nipple I think) and goes behind the injector cover, then out in the breeze. Where does it plug in?
Thanks—
Thanks—
What engine you have?
For him: 2005 V70 R AWD & 1998 V70 R FWD manual BSR Stage 1
For her: 2005 S40 1.8
Ex: 850 T5, 850 2.0 20V, S40 T4, 245 2.0 and some others
Pictures here
Pictures here
- phils94850
- Year and Model: 2009 s60 turbo
sounds like the vac line that goes to your fuel pressure regulator.
1996 Platinum Edition
JimBee
The engine I think is the 2.4 L, '93 850. Hmmm. fuel pressure regulator. The line is by the fuel rail; not sure what the regulator is—the horizontally mounted barrel? Come daylight, I'll have another look.
Thanks!
Thanks!
I have a 2.5liter V70 at home.. Will do some pictures this evening. (in about 8 hours..)
Pictures here
Pictures here
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The FPR is on the underside of the fuel rail there, between cylinders 1 & 2.The line is by the fuel rail; not sure what the regulator is—the horizontally mounted barrel? Come daylight, I'll have another look.
Thanks!
'98 S70 T5
2016 Chevy Cruze Premier
- 798 Views
Last post by v-45magna
- 685 Views
Last post by Eddystone
- 933 Views
Last post by EstVolvo
- 949 Views
- 13 Replies
- 2554 Views
Last post by RickHaleParker
