I have some time before I should have to address this.
Can anyone definitively tell me if the Volvo V8 (which I
gather Yamaha designed and built) uses an external timing
belt (as many previous Volvo models do) or an internal chain ?
I ask only as I have talked with several dealer service departments
and it is about 50/50. I am guessing the service advisers honestly don't
know and pick an answer.
Best info I have is a marketing brochure showing a cut way view.
It shows what looks like a chain, but it is a sales piece.
Thanks to all.
V8 timing belt or chain? (2008)
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
I don't know, but can't you look at the 'front' of the engine for a clue? Sounds pretty sad if the dealer(s) can't tell you....
- RickHaleParker
- Been thanked: 978 times
Design specs by Volvo. Engineering and manufacturing by Yamaha.
Same engine block is used for the Yamaha F300V8, F350V8, and XTO Offshore outboards. Got to wonder if the lower end from a Yamaha outboard can be used to get up to 5.6 liters of displacement and up to 425+ hp. The XTO 425 is 5.6L 425 hp.
Active
Past
Past
- Has thanked: 987 times
- Been thanked: 1075 times
RickHaleParker, I encourage you to try the 5.6 L modification after you get your V8 project sorted out.RickHaleParker wrote: 26 Oct 2020, 18:11Design specs by Volvo. Engineering and manufacturing by Yamaha.
- RickHaleParker
I don't think so. The 5.6 is only two years old and they are $45,000 engines. I would need the crankshaft, rods and pistons from a 5.6. Different stroke and bore. In other words a short block 5.6. That is if the crankshaft will bolt to the Volvo transmission. Heads on the 5.6 are reverse flow, exhaust manifold is between the heads. Would need to use the Volvo heads unless I route the exhaust out the hood.volvolugnut wrote: 26 Oct 2020, 18:33 RickHaleParker, I encourage you to try the 5.6 L modification after you get your V8 project sorted out.![]()
The 5.3 is the same bore as the 4.4.
Active
Past
Past
- 2486 Views
Last post by jimmy57
- 2887 Views
Last post by ikeever
- 755 Views
Last post by j-dawg
- 915 Views
Last post by kublaiboy
- 11 Replies
- 15945 Views
Last post by RossJonnes
