Draper tool problems
99beast_
Year and Model: 1996 850 wagon
Post by 99beast_ »
I purchased a new Draper tool to reset the service light after an oil change. When I plug it in to the data port on the console, the green light comes on immediately. I tried the DIP switch #2 and the #3 in the on position as described in the directions. Did I get a bad tool or am I doing something else incorrectly?
Thanks,
New to this site. Owned the 1996 850 wagon for just over a year.
mindshadow
Year and Model: none
Post by mindshadow »
I always feel bad making jokes on this forum because people need help (and I've received a lot of help here), but your mention of draper tool problems makes me think of sad Don Draper from Mad men.
IVIUSTANG
Year and Model: 2006 XC70
Been thanked: 4 times
Post by IVIUSTANG »
You should check the directions again, for my car it is dip switch #1 on, and all the rest off. I have an S70 though.
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires :D
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
99beast_
Post by 99beast_ »
The directions for the 850 read dip switch #2 on and all others off. If this does not work, then dip switch #3 on and all others off. The green light comes on and stays on as soon as I plug it in.
IVIUSTANG
Post by IVIUSTANG »
From memory, you plug with unit into the OBD port, turn your ignition key to on, then press reset. The green light then flashes for 5 seconds and goes solid when complete, then turn off your ignition and remove the draper tool. I'm assuming you did this as you read the directions included :) Otherwise something must be wrong with the tool.
- Jesse
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Orrrr you can just take the service bulb out and smash it like I did :D
'98 S70 T5
2016 Chevy Cruze Premier
