I checked the forum, but nothing is listed, so hopefully someone can help me with this:
Each time I press on the brakes, A yellow light with a picture of a light bulb illuminates. Anybody know what this means???
I have a 95 850 GLT, non turbo.
Thanks!
Picture of a "Yellow Bulb" iluminates on dash
bronxnativ
- Year and Model: 96 850 GLT 5 Speed
Al
bronxnativ
Thank You Icelandic!!!! I was pulling my hair trying to figure this out. I thought maybe it was related to the brake fluid level. Again, I appreciate your reply!
Al
That bulb will iluminate upon steping on the brake whenever one of the brake lights is burned. If it iluminates continuously when you have the beams on, it means one of the running lights is burned (might be the beam bulb or the corner light bulb)
Good luck!
Good luck!
1995 859 auto NA
- Year and Model: Many Volvos
- Been thanked: 76 times
Even one of the high mounted 3rd brake light bulbs burning out will trigger the fault light.
When it comes to brake lights, tail lights, and headlights I always replace them in pairs or in a set in the case of the brake lights.
When one goes the other usually isn't far behind.
bronxnativ
Thanks Lee. Appreciate your input also!
Al
- 779 Views
Last post by CIK7
- 13 Replies
- 4287 Views
Last post by Clemens
- 1412 Views
Last post by beigg
- 4908 Views
Last post by adrian22
- 4175 Views
Last post by silentcircuit
