My 850R (Auto) failed the MOT as the tester was unable to maintain a "fast idle".
When the engine is running it idles at around 1100 rpm, but it is impossible to get it maintain steady revs with the accelerator pressed. It gradually rises to where you need it then carries on revving up until around 3500. If the IAC is unplugged the revs drop to around 800rpm and it is possible to increase them gradually to where you need them.
Things I have tried:
- 1. Cleaned IAC
2. Replaced IAC
3. Cleaned Throttle body
4. Replaced TB and TPS
5. Tested voltage to IAC plug - Ignition on but not running - 12v between 1&2 and 3&2. Engine running - 14v, no change when throttle moved.
