Bad Shutter In Reverse
tjg
Year and Model: 940 1995,XC70 1999
Has thanked: 3 times
Post by tjg »
My 1999 V70XC makes loud and hard shutter when put into reverse. Heard this can be caused by bad motor mounts or are we looking at transmission problem? Thanks TJG
1995 940 TURBO SW
1995 850 TURBO SW
1999 V70CX
Previous
1993 940 TURBO(CRUSHED BY TREE)
1989 240(CRUSHED BY SAME TREE)
1972 142 SOLD
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Try checking your transmission mount under the car. It looks like this:
See if it has excess play trying to wiggle it all directions or if there is evidence of the rubber falling apart. If so, that would probably be a good place to start.
Also, when was the last time you had a transmission fluid change?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
tjg
Post by tjg »
Transmission mount okay and the fluid changed 11,000 miles ago. Seems like engine has hesitation problem under load now noticing slight shudder when going up hill. Could this be engine problem or transmission problem?
1995 940 TURBO SW
1995 850 TURBO SW
1999 V70CX
Previous
1972 142 SOLD
