need help with front bearing hub removal
rrooby
Year and Model: 850 1996
Post by rrooby »
http://volvospeed.com/Repair/FWDbearingHub.php
So I followed these instructions and tried to replace my wheel bearing hub but I can’t get the hub & the knuckle to separate. I hit it couple time with the hammer nothing.
I ended up just replacing the axle but I need to replace the bearing hub also, how do I get this thing out?
bobbych
Year and Model: 1994
Post by bobbych »
i had to remove the hub, whack it in a vice, and chisel mine apart
1994 850 TURBO
Metallic Grey
Full Leather
rrooby
Post by rrooby »
I think im just gonna buy another knuckle
WHere can I get a knuckle for cheap??
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
www.vandsautodismantlers.com
Give those guys a call. Those Torx bolts were a complete PITA on mine, and that's where I got stuck (I actually BROKE two socket wrenches just pushing on them) even after getting the IMPOSSIBLY seized up axle nut off.
'98 S70 T5
2016 Chevy Cruze Premier
57buzzard
Year and Model: 1998 V70 AWD
Post by 57buzzard »
If you have all the bolts removed...crack the nuckle with a hammer around the base of the hub assembly.
This may loosen it enough to give it a good crack with 40 oz hammer on the inside to dislodge it.
It worked for me last week.
Steve
reluctant_mechanic
Year and Model: 850 GLT 97
Post by reluctant_mechanic »
I'd use a little heat on the bolts before turning them. It worked for me when changing out the lower control arm and when removing a broken bolt from the SAS valve. I was able to remove and reuse the knuckle bolt retaining the ball joint after applying heat from a map gas plumber's torch. Be careful not to have any solvents or fuel around or on the part.
rrooby
Post by rrooby »
I got all the bolts of no problem Took me like half hour to get the E14 torx off but the hub would not budge
Red-Arrow
Year and Model: 850 T5 1995
Post by Red-Arrow »
Great tip guys, never used a heavy hammer that you can only swing a low speeds. I always recommend light weight fast strikes from a 12 ounce ball pen hammer. Never found a ball joint or weight bearing that didn't move after a few super fast whacks. It can take 5 or 50 hits bit it will move. Also spray on something like WD40 and let it soak.
Life would be enjoyable if it wasn't so painful to live.
reluctant_mechanic
I would def. use heat. Try heating the part you are gonna remove near where it joins the hub. You can try several heating and cooling down cycles and that will probably free the part with a bit of tapping. I would try to not beat on the part that captures the bearing.
I will probably be changing out the bearings on my car before too long, too; so if you could keep us informed, it would be great.
Thanks
97 850 GLT
rrooby
Post by rrooby »
:D I finally got the bearing off I ended up using some penetrating oil & letting it sit for about an hour, and the hub fell out after 3 good tap
Thanks for everything guys
