Left Front Noise From Tire, Bearing Or?
Esnoyer
Year and Model: V70 03
Post by Esnoyer »
Going around right or left on or off ramps makes no difference in the sound .Two Volvo dealers say its a puzzle.even installed a new rim and tire from a new demo they all make the same sound,They say it is not a bearing or CV joint,this is really starting to p#%s me off. :
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Does the noise change with braking or acceleration at all?
'98 S70 T5
2016 Chevy Cruze Premier
Esnoyer
Post by Esnoyer »
Breaking makes no change ,replaced all rotors and pads recently,when the noise started I thought it was a damaged tire, changed LR to LF same sound,you would think Volvo Dealers could find the reason but?????????
Some Dealers want $$$$ to have a mechanic road test and analyze the problem, they will remove the charge from the repair..
Have gone through this same end result Woopy S++t
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Bad wheel bearing
Bad left axle
or both
IgorA
Year and Model: s40 1997
Post by IgorA »
Please update on this matter, as I have exactly same problem.
Was it bearing or ????
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Dust shield touches rotor?
