Hello everyone,
I just bought this car and it needs some maintenance.
It has got 79500 miles on it and ATF color is pretty dark and needs to be flushed.
I did change the ATF on my S80 and used Dexron 3 but not sure what type of ATF this S60 gets.
Thanks for your time in advance...
2004 S60 AWD 2.5T - ATF Question
neworleans
- Year and Model: 2007 S60R
Mobil 1 JWS 3309 (has to be ordered), 3309 spec fluid from the dealer (usually expensive), or Toyota T-IV ATF (cheap and readily available at your nearest Toyota dealer). To my knowledge you cannot or should not substitute any other fluid for any of the 3 mentioned above. For your reading enjoyment there are about a bazillion threads regarding this topic, some here and many on other Volvo forums as well.
neworleans
I'd like to compare the prices, can you tell me where to order the Mobil 1 JWS 3309 from?
There is a Toyota Dealer right next to my place, I will ask them today.
Any preference between the two? or pretty much the same?
Thank you..
Thank you..
The link below is the only place I know to get the Mobil 1 fluid, probably other places as well but I haven't looked. The Toyota fluid should be between $4 and $6/per quart. By the time you factor in shipping it usually is the cheapest route. To my knowledge there is no difference between any of the 3 fluids mentioned, all meet the same spec. I've been using the Toyota fluid in our cars for the past 3-4 years and haven't had any trouble. Your next dilemma will be deciding whether to drain and fill or flush via the trans. cooler hose at the radiator. I like the flush but many, especially on higher mileage vehicles like the drain and fill. Many topics out there on this subject as well.
http://www.avlube.com/mobilatf3309.html
neworleans
Thank you very much.
neworleans
I got the TP-IV Toyota ATF today ($5.48 a qrt) to change the fluid but the bolt was huge, couldn't' take it off.
Do you know what size of wrench do I need to drain the transmission fluid??
Thank you.
Thank you.
neworleans
Hey Guys,
I finally found the 15/16 wrench and did change the ATF today. Thankfully volvo made this so easy. When I drained my S80 I had a very hard time, when I pulled the filter, the pipe section where goes in to the tranny broke and I sweated my ass off to take off that small piece, so I didn't have to deal with all that on this car.
I drained it 3 times, when you drain it, 3.5 qrts drain. I attempted to flush it through the Radiator hose after the first drain but damn hose didn't come off. So I had to drain it 2 more times (bought 12qrst Toyota TP-IV ATF), drive it little bit and get on the ramps and drain it again. It took me about 2.5 hours.
Thank you all very much for your help, I will be around with more questions
- 11 Replies
- 11948 Views
Last post by STSCowboy
- 1053 Views
Last post by precopster
- 373 Views
Last post by combsb97
- 616 Views
- 10 Replies
- 739 Views
Last post by foggydogg
