Just bought this car, 1995 Volvo 850GLT. It started fine and drove home. The ABS and Check engine light were on but go off after the key is wiggled. I read in another post that the ignition switch simply needs to be replced and the idiot light issue will go away. Parked the car at home.
Now, the car will not start and nothing in the car has power. The battery has 12.5 volts but nothing in the car works.
Is this related to shorted ignition switch or is there a different problem?
Any help would be appreciated.
Eric
Car has no electricity but battery has voltage- Volvo 850GLT
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Replacing of ignition switch will also make your 'no electricity' problem go away.ericinatl wrote:The ABS and Check engine light were on but go off after the key is wiggled. I read in another post that the ignition switch simply needs to be replced and the idiot light issue will go away.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
Ground wires. I'll second that. The ignition switch is fairly easy to replace.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
I ordered the switch. The local auto store wanted $110 but it was available for $54 at fcpgroton.
Are you talking about the ground wires under the hood? I plan to disconnect and clean those today.
Thank you for the advice. I'll let you know the outcome.
Eric
Eric
