Did you know? 🤔
440 LE 1991 - Cooling fan doesn't switch off
Discussion and advice for 440, 460, 480 owners.
1986 - 1997 440
1986 - 1997 460
1986 - 1997 480
buskermike
Year and Model: 440 LE 1991
Has thanked: 0
Been thanked: 0
buskermike
Post by buskermike » Tue Oct 20, 2009 8:58 am
Hi. I'm a new member. I've got a 1991 440 LE with a B18 KP 111 engine. The cooling fan is not switching off when it should do. It appears from the Haynes manual that it is controlled by a timer relay that in turn is controlled by the engine temperature sender. I can't find the timer relay. Does anyone out there know where it is?.
Thanks,
Mike
Siim_S
Year and Model: 460 GLE 1995
Has thanked: 0
Been thanked: 0
Siim_S
Re: 440 LE 1991 - Cooling fan doesn't switch off
Post by Siim_S » Mon Nov 29, 2010 4:39 pm
Hi!
I'm having same problem on my 460 GLE 1995 with 1,8i engine.
The fan continues working with cold engine. Any ideas?
Siim
billofdurham
Year and Model: 855, 1995
Has thanked: 0
billofdurham
Post by billofdurham » Tue Nov 30, 2010 3:21 pm
This is the only information I can find for a cooling relay for the 440.
440 relays.pdf
(82.37 KiB) Downloaded 250 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Siim_S
Has thanked: 0
Been thanked: 0
Siim_S
Post by Siim_S » Tue Nov 30, 2010 11:58 pm
So there isn't such a thing like cooling fan timer relay? Or is there any other place than this to find relays?
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Wed Dec 01, 2010 12:32 pm
I am not aware of any car having a cooling fan timer. The fan is switched on by the engine control unit when the temperature reaches the prescribed limit. When the temperature falls to an acceptable level the ECU switches the fan off. This is done by activating and de-activating the fan relay. On cars with air conditioning the fan will switch on if the AC is switched on to assist with cooling the condenser which is mounted in front of the radiator. In this case the fan will remain on as long as the AC is on.
There are other relays listed for the 440 but none to do with the cooling fan.
Bill.
Previously:
yuckuJackD
Year and Model: XC70; S80; S40
Has thanked: 0
Bulgaria
yuckuJackD
Post by yuckuJackD » Mon Jan 17, 2011 5:16 pm
The fan is controlled electricaly by a temeperature switch located in the left center side of the radiator. It is cheap - replace it.
It stays in the whole marked az M20x1.5 in the picture above and looks like the picture below (the plug may not be exactly the same, depending the model used in your car):
And it has 3 wires: "+"; "low fan speed" and "height fan speed". The "+" is awways connected to the battery (through fuse in the fusebox), the other two are dirrectly connected to the fan
Other reason not to stop the fan is short near that switch or near the fan plug.
Third reason mentined abowe "locked" relley. I don't remeber but I think there was no relley for that... Idea: the releys are not so much... while fan is working when it shouldn't just unplug all the relleys one by one until it stop. This way you could locate whether the problem is that (I don't think so...)
Good luck.
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
