Hi all,
I'm replacing the lower A arms on my '97 850 glt and the driver's side went fine. Passenger side, (right side) however is giving me problems. I can't get the strut close enough inward to connect the arm. It looks like the axle might have come out of either the center bearing or the transaxle but look at the boot stretched out. What do you think happened here and how easy is it to fix, at this point? Thanks.
97 850 A arm problem, maybe axle problem
- Year and Model: Many Volvos
- Been thanked: 76 times
It looks to me like you pulled the inner CV joint apart. You can remove the boot and try to put it back together but you will need a new clamp for the boot.
confused_al
- Year and Model: 1996 TLA wagon
If that boot is old, I would just replace it since you need take it off anyway. Wouldn't you?Ozark Lee wrote:It looks to me like you pulled the inner CV joint apart. You can remove the boot and try to put it back together but you will need a new clamp for the boot.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
The axle assembly is only about a year old so the boot is still very pliable. I was able to pull the boot back and was amazed to see how simple the cv joint is. I'm used to balls in a cage type found on VWs. With the spring a bit compressed with compressors, I grabbed the hub assembly, still containing the rotor, caliper,etc., with a bear hug and lifted and wrestled a bit while pushing and ...pop, the cv joint went back into the cavity. I quickly put the ball joint stud up into the hub and ,,,whew! done!
Thanks guys!
Thanks guys!
Greg Z
'97 850 wagon
'97 850 wagon
- 2475 Views
Last post by Kazthebassman
- 13344 Views
Last post by MarcM
- 2922 Views
- 2975 Views
Last post by 800artfreed
- 23 Replies
- 3271 Views
Last post by 850forum
