T5 engine from a Volvo 850 to a S40, will it work?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
it is not wider between the inner fenders in engine compartment. Raise hood and measure the rough dimension of current engine from back to front of cam cover and then do that measurement on the T5 engine. Now look down at front of engine for the available extra room for a longer engine. Is the added length of the T5 engine available in the space not used by the current engine?
Next problem is the bracket to attach engine mount on front of engine. The holes in the S40 engine to use foe the bracket do not exist on the 5 cylinder. Nedcar S40 hangs its motors while the T5 motor is supported on the bottom.
There is a lengthy list of hardships to overcome. You can't move the trans closer to the left side as then you need expensive custom driveshaft work and you will lose the torque steer cancelling effects of equal length drive shafts .
- 2173 Views
Last post by Scooby750
- 2318 Views
Last post by Vovo_merz
- 11829 Views
Last post by Our2C70s
- 2581 Views
Last post by BorisBadenov
- 992 Views
Last post by lext
