Sounds like you have two issues. Battery and transmission (flashing arrow).
At night check your 850 for any lights on. For instance, my 850's trunk switch is broken. If I have the light switch set to "door", the light stays on even if the trunk is closed. Cost me a battery (that probably needed replacing in the next year anyway).
Look for the glove box light staying on. Listen for fans running. Etc. If it's none of that then you need to move to the next step: find the draw on the system with a voltmeter.
With the car off you test each circuit by removing a fuse, testing for current, repeat.
As for the arrow, get your codes:
http://www.troublecodes.net/Volvo/
Then report back here with the code and I'll help if I can.
volvo 850 help Topic is solved
- Has thanked: 2866 times
- Been thanked: 1332 times
Guest
ok matthew can u tell me how to do the fault code thing abd i will let u knowmatthew1 wrote:Sounds like you have two issues. Battery and transmission (flashing arrow).
That link says how to get your codes.
I don't know.
I have a '97 so I'm not familiar with the under-the-hood code retrieval method. Perhaps someone else here can shed more light on it for you.
White850Turbo
- Year and Model:
Yes, you must place the connector (ground) in the corresponding socket (A1 is for the transmission, A2 for engine/fuel system, A3 is for brakes)
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
- 1372 Views
Last post by CEBirnley
- 2031 Views
Last post by darylrobert
- 1561 Views
Last post by Craigd2599
- 27 Replies
- 2697 Views
- 9 Replies
- 2194 Views
Last post by Sommerfeldt
