Replaced the one way valves a short time ago and only get a trickle of fluid from the windshield sprayers. Is there something I'm not doing correctly? They worked fine until the valve went bad, now I get nothing to the front or back wipers.(washer fluid)
Jim
Windshield Washer
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
How many did you end up replacing? It sounds like pressure is still escaping somewhere. Here's the whole parts list for a V70. It looks like there's 3 multiple-way valves in the system.
'98 S70 T5
2016 Chevy Cruze Premier
neil wilton
- Year and Model: 850r 1996
blow the hoses out to as you check them as ive found over years of window washer fluid can set like concrete.but be care full no to blow the lines off in hiden areas.
- 15 Replies
- 8920 Views
Last post by volvolugnut
- 36 Replies
- 25028 Views
Last post by StickyPocket
- 531 Views
Last post by ZionXIX
- 4492 Views
Last post by eyerollXC70
- 555 Views
Last post by Duncx
