I have no blinking arrow but I have no reverse lights. Granted, it's been like that for awhile now but since I need to get the car inspected I actually have to deal with it now. I used to be able to get them on pushing the shifter all the way forward but that no longer works (hasn't worked for awhile).
I tried realigning the switch, but unless I'm missing something I got no where. I tried moving the switch the entire range of the reverse gear and the reverse lights never came on. I know it's not a fuse since the turn signals are on the same fuse and they work just fine. I also checked the light bulbs on the off chance both were blown and they looked fine. Also, if they were out, wouldn't the light warning come on when in reverse if the pnp was working properly?
Now, Maybe I was missing some fundamental on the alignment, but I did find it challenging to keep the shifter arm and shaft from moving when tightening the shift arm shaft nut, but I was able to do it with the flat head in the slot on the shift armer.
I've also tried the ratcheting method as well, and no luck there.
There is no problem with getting into and out of gear. Occasionally there is a clunk when coming out of park or going from R to D but I always figured that was just a worn engine mount.
So, time for a new switch or is there something else to try? I don't mind getting a new switch, but don't want to replace it if it would cure the problem.
Time for a new PNP switch?
Sladethesleeper
- Year and Model: 1998 S70T5
1998 S70T5 - 210k miles
1998 V70GLT -110k miles
2004 Chevy Silverado 1500 Z71 - 305k miles
1965 Mustang Convertible
I like miles...
I like miles...
hammertime
- Year and Model: '04 XC90, '07 XC70
I can't say if you need a new one or not, but I thought I'd give you this info: There is a wide price range for this part across the internet parts suppliers. Search them all before ordering. I saw OEMs for as much as $170. A little more than 2 years ago I found one for my 850 made by AC Delco for $56. It works just fine. Now my S70 needs one and days of searching turned up nothing that cheap. Apparently AC Delco discontinued it. Best price I found was for a ScanTech made switch from Groton. Came in the mail just the other day. Now if we could just get a break from 5 degree Farenheit weather, I'd put it in.
'04 XC90
'07 XC70
Zamboni Model 545 (my work vehicle)
Prev. '68 142, '96 850 GLT Sportswagon, '98 V70 AWD, '98 S70 T5, '00 V70 XC
first car ever owned: '74 BMW 2002tii
'07 XC70
Sladethesleeper
Yeah, I hear you about the weather. I did an inner tie rod, air pump, and check valve this weekend. None to warm. Luckily I have a very warm and thick pair of coveralls back from my Marine Inspection days. I was going to pull it into my garage, but one bay is my general workshop and the other bay has my 65 mustang. The mustang had a dead battery and I didn't have time to charge it.
I'm just trying to make sure I'm not missing something else prior to dropping another $160 (or $85 for scantech).
One of these days I'll get sick of my love affair with these volvos.
I like miles...
I like miles...
Id stay away from the scantec part. I've heard some bad experiences on here about those.
There is a thread on here about rebuilding your switch. Its easy, and you know you have a good part. I did it and it solved my issues. Plus, if you mark the bolts, you don't have to mess with re aligning the switch.
93 850 GLT sedan 156K
94 850 Turbo 189K
94 850 Turbo 189K
rommel0915
- Year and Model: 1995 Yellow 850 T5R
I also rebuilt mine and works great. Just follow the write up and you should be fine.
1995 Volvo 850 T5R (Yellow)
1995 Volvo 850 Turbo
Sladethesleeper
I saw the write up about rebuilding the switch.
My question, were guys having the same issue with reverse lights? I guess I don't really lose anything from trying it and I still have the car mostly torn down to that point so it won't be too hard to do.
I like miles...
I like miles...
rommel0915
I agree! No reverse lights = PNP switch rebuild.
prior to taking switch out may I suggest you gain access to the electrical connector the switch connects to and separate it to access the pins and determine whether pins 5 and 9 on the connector are shorted when the transmission is in reverse. I believe these are the reverse switching part of the switch. Just a thought and if someone knows better I defer to their knowledge.
- 11 Replies
- 11518 Views
- 1675 Views
Last post by beigg
- 1607 Views
Last post by davidvinograd
- 40 Replies
- 17078 Views
Last post by Oly850
- 1079 Views
Last post by tardcart
