Electronic Throttle Module
smrufo
Year and Model: S70 2000
Post by smrufo »
S70 2000; failed and was replaced at 65,000 miles during the time of the recall, is again failing at just ~60,000 miles since replacement. Is this normal? Seems to me they may not have fixed the problem to begin with...Anyone else hearing problems with this?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Nothing TO fix, they fail.
They can fail at 40K or as long as 135K
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
My original was still strong at 150,000 miles, but I decided to swap it out for an XeMODeX unit (remanufactured unit does not fail like originals) as preventative maintenance.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
smrufo wrote:S70 2000; failed and was replaced at 65,000 miles during the time of the recall, is again failing at just ~60,000 miles since replacement. Is this normal? Seems to me they may not have fixed the problem to begin with...Anyone else hearing problems with this?
This is probably one of the biggest mistakes Volvo ever made...
There's a whole forum section here that's devoted to the topic:
https://www.matthewsvolvosite.com/forums ... m.php?f=12
Short answer -
Give your great car a version of the ETM that won't die:
http://www.xemodex.com
EstVolvo
Post by EstVolvo »
Did Volvo ever use ETM that won't die - during the recall and as original?
PCars
Year and Model: 850 Turbo Sedan 1996
Post by PCars »
I remember the original ETMs were from an italian manufacturer and almost always failed, even after the cleaning attempt. I believe they did extend the coverage on affected vehicles to 10 years/200k miles. Might be worth a phone call to the dealership.
'96 854 Turbo
'84 244 FI(sold)
'81 244 CI(sold)
E170_Driver
Year and Model: bye V70 2.4T, 2001
Post by E170_Driver »
Exactly the reason why I told Volvo that I would never buy another one. Replacing a wear/tear item with another one shows me that Volvo opted to bypass the right and safe thing to do: Coming up with a PERMANENT fix. When I had my 2001 V70 and learned about this issue, I wouldn't let my family drive in it. I loved my vehicle, but unfortunately Volvo management proved to me that $ was more important to them rather than fixing the issue at hand, bye bye V70. Shame on them and yes other car companies are not better, but in this case it is so evident.
Jan
Former 2001 V70 2.4T owner
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
No; the replacements are the same design too.
If you're out of warranty, you can go the Xemodex option that uses components that won't fail.
'98 S70 T5
2016 Chevy Cruze Premier
JRL
Post by JRL »
Don't scare everyone, the 02s and newer are a different design and manufacturer
The 99-01 were made by Magnetti-Marelli
When I was young and rich I owned a few Ferraris
The early 1969-1971 Daytonas had an MM ignition, failed with alarming regularity
In 1972 they switched to smaller Bosch units, they never failed
jblackburn
But that doesn't apply to the model asked about ;)
'98 S70 T5
