P0410 Code
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
The relay is mounted right next to the pump and is probably best seen from the underside of the car. To help, it looks quite similar to the fan relay which is mounted above the radiator.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
Dave123
Year and Model: '03 S80, '98 S70 T5
Post by Dave123 »
Thanks....I'll give it another shot.
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
Dave123 wrote:Thanks....I'll give it another shot.
Did you find the relay? I was told the same thing about it being one of the relays on the fan shroud.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Dave123
Post by Dave123 »
Snowed last night so will have to wait to see where it might be.
shiloh51933
Dave123 wrote:Snowed last night so will have to wait to see where it might be.
Yeah it snowed here too and is cold as a mutha right now. When you crawl under you ride it's right under air pump, you have to drop the skid panel down to see it, it looks just like the big relay on the fan shroud but the prongs are a little different.
vjaneczko
Post by vjaneczko »
shiloh51933 wrote:Did you find the relay? I was told the same thing about it being one of the relays on the fan shroud.
Only one relay on the fan shroud - and it's for the fan.
2006 S60R - For ME!
shiloh51933
Mine has two and one of them looks just like the sir pump relay. The air pump relay is located right under the air pump itself, drop the front skid plate down, it's the skid plate connected to the front ground effect. n Look on the battery side and you'll see the relay with the air pump right behind it, you can't miss. It will take you all of about five minutes to change it out...taking a tire off is more complicated than changing this relay, lol.
Dave123
Post by Dave123 »
So here is the deal on my s70. The only wires coming out of the pump are the ones that go to the connector. The connector is located just behind the driver side headlight. I don't have the configuration shown where the relay and ground coming out of the pump are located right next to the pump. So where is the relay? Hate to think that I have to go to a dealer, yikes!!!! :o
Volvos rock3
Year and Model: v70xc, 2002
Post by Volvos rock3 »
on our 96 the relay was actually zip tied to the pump, the first time the pump threw a code it was for a loose wire in the relay, fixed it 6 months later another code...dead pump (that only runs for less than a 120 seconds upon start up) and it remained that way until we traded it...no performance issues. good luck!
1996 850 GLT sdn (deceased)
2002 V70XC 118k
2009 S80 3.2 37k
1998 Chevrolet K1500 84k
1965 Pontiac Lemans convt
2009 Chevrolet Tahoe PPV 2x (work)
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
I'll take a look at my S70 tonight; I did that over 3 years ago and can't remember where the relay is to be honest.
'98 S70 T5
2016 Chevy Cruze Premier
