How To Remove S60 Radio/Climate Control Center Console
This topic is in the MVS Volvo Repair Database » Volvo 850 Buying Experiences
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Instructions sent to me by Jim. Thanks Jim!
Also -> Amazon link
archiman
Post by archiman »
Anyone know how to install the in-dash cup holder on an '05 S60?
Thanks
GavinV70
Year and Model:
Post by GavinV70 »
Just want to mention how IMPORTANT it is to disconnect the battery before removing the two electrical connections to this unit!
Failure to do this will result in an SRS fault being logged which can only be reset by a Volvo dealer running the VADIS software.
Volvo V70 T5 '02 - Ex-Police (Dark Blue)
Arbelac
Year and Model:
Post by Arbelac »
The piece on how to remove the CCM is -WRONG-. Don't angle it upwards. Pull out the bottom just enough to get a finger or two in, then slide your fingers up, and pull the CCM straight out.
-1998 V70 Cross Country Wagon, B5254T, AWD, 231000KM
- 2001 V70 T5M, FWD, 205000KM, QBM Strut Brace Conversion, QBM Poly Lower Transmission Mount, HD Endlinks
xmscott
Year and Model: 99 S80
Post by xmscott »
Somewhat related.
I unclipped the the shift console.
What time of screws are used in the S80? To remove the climate cluster.
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
for newer cars, I believe '04 and newer, the CCM and radio are 1 unit. So when you pull at the bottom the whole CCM/radio cluster comes out.
Archiman to install the in-dash cup holder in the '05 S60, remove the whole unit and remove the screws behind the empty holder to remove it and install the cup holder. By the way, afterwards if you don't need the plastic empty holder, I need one and can take it off your hands.
deebs
Year and Model: S60 2006
Post by deebs »
GavinV70 wrote:Just want to mention how IMPORTANT it is to disconnect the battery before removing the two electrical connections to this unit!
Gavin, or anyone that's done this before, what does the SRS fault actually do? Are you unable to start the vehicle if you dont do this? And does unplugging the battery first 100% guarantee that this can be avoided?
I'm considering installing a USA spec ipod adapter but worried as this is the first vehicle I've owned with this kind of potential issue if you dont disconnect the battery. Appreciate any additional advice you folks can offer with regard to important thing to watch out for before I take apart the climate control/radio. Thanks!
jda2000
Post by jda2000 »
SRS fault means the SRS light will come on and you'll need the dealer to turn it off. The car will run fine otherwise.
That's why you need to disconnect the battery, before unplugging the radio/CCM unit.
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
When the SRS light is on, it also means the airbags are disabled!
1997 855 GLT - R.I.P.
2006 S60R - For ME!
