Hi ,
Our 850 hit a pothole today , the tire was new and the rim was servicable.
Rim: Can you please tell me if the rim looks like it can be used again. Looks are not so important, so I was thinking that the edge of the rim could be hammered out and it may hold a tire.
If anybody knows where I can get another rim, please let me know .
Tire: I have no idea but can a tube be put in that tire and can the tire be re-used. The picture shows 2 small
cuts in the sidewall of the tire, my guess is that its toast but I thought I would ask if using a tube is an option when the tire is damaged like this one is :
Thank you.
Tim
in NYS
Hit pothole, is this tire + rim toast ? 96 850
- rollin_home
- Year and Model: 99 s70, 08 s60, xc70
- Been thanked: 9 times
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The tire is dead. You don't want to risk patching that and then have it blow out on you and lose control. (I've had a blowout before - it's not fun).
The rim might be OK if it will balance out and hold air.
'98 S70 T5
2016 Chevy Cruze Premier
looks like they are both toast. you can get one on ebay or a local junkyard if you are quick enough.
http://cgi.ebay.com/ebaymotors/91-96-VOLVO-850-RIM-WHEEL-15-INCH-OEM-PS1-_W0QQcmdZViewItemQQhashZitem1e61b27810QQitemZ130488104976QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
That looks pretty bad. There is a big chunk missing off the lip and I doubt a tire would be able to seal itself to that rim. I wouldn't even go through the trouble to try fixing it. Just scrap it and find another rim. Scrap value is about $10 for alloys.
Check your local Craigslist. Those rims are very common and can be had for at least $35-60 dollars each. Depending on condition. Ebay for sure has them in the 5 lug bolt pattern. If looks aren't that important like you said, a steel wheel would do the job for even cheaper.
- Year and Model: Many Volvos
- Been thanked: 76 times
That wheel is named Cetus and it is the most common of all Volvo wheels. Check with member Confused Al, I think he may have a set on his parts car.
confused_al
- Year and Model: 1996 TLA wagon
Where are you located?
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- rollin_home
I am at top of the Garden State Pkwy exit 172.
http://strandbergauto.com/
good quick service
volvo wheels have a number on the inside of them and you can match to one listed on their site
tire is toast
good quick service
tire is toast
99 V70XC 158K
95 850glt 188K
95 850glt 188K
- rollin_home
Thanks everybody. Numbers are 6.5jx15x43 6040 k11 9140545
- 1412 Views
Last post by callahanoffroad
- 1710 Views
Last post by s2zeller
- 2026 Views
- 182 Views
- 13 Replies
- 2179 Views
Last post by Georgeandkira
