i just replaced the brake booster in my s60.
if i do a gravity brake bleed will i need to pre bleed the mc first?
also, do i need to bleed the abs?
thanks!
brake bleeding
DIY: 1998 V70 ECT (Engine Coolant Temp) Sensor Replacement
darkcountry
- Year and Model: S60 2003
darkcountry
cool thanks for the info. thats the good thing about brakes...you'll know pretty soon if ya got it right hahaha
im guessing the only way to avoid bleeding the mc is to use a pressure bleed?
darkcountry
how can you take the mc off the booster without disconnecting the lines? theres no way to get the booster out without at least disconnecting the abs lines...
darkcountry
man i wish i knew that trick!
darkcountry
jda2000 wrote:I did the replacement myself a couple of months ago and I did not disconnect the hydraulic lines.
I am glad I learned this tip from a volvo tech at another forum, just before I did the job.
anyway you could post how you did this? thanks
