Turn Signals Dont Work?
yuckuJackD
- Year and Model: XC70; S80; S40
- Been thanked: 2 times
Other posibility is the hazard switch. The turn signal wires comes from the turn selector switch and and goes to hazard switch. Sometimes the hazard switch makes bad contact with the plug. Could be the same problem with the turn selector switch - bad contact with the plug.
Clean and check all elektrical conections.
Your fuses are OK, don't loose time to check them.
GOOD LUCK
GOOD LUCK
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
ksanthony
- Year and Model: v40, 2000
How do you determine if it is the selector switch. My signals worked one day, then I noticed the weren't working, next thing I knew they were working again. They have again, quit working. Suggestions?
ed7
- Year and Model: V70XC 2005, 2001
- Has thanked: 2 times
If the dash indicator comes on, but doesn't blink, you have a bulb not working. If the indicator and exterior bulbs illuminate, but don't flash, the blinker unit is kaput.
Check bulb connections in their sockets and the socket's bayonet connections to the lamp assembly.
After all that and you still have nothing, look toward the stalk assy.
Ed
Ed
volvo_novice
- Year and Model: V40 2000
Ramin182 did you fix the problem? I have the same problems. Thanks
I have similar problem in my V40 T5 wipers. When I switch on the wipers, nothing happen. I had changed wiper motor and wiper control stick, but still fail. Finally, I changed CEM (Central Electronic Module), every resume normal. You can locate this module down in the steering. Just move out 6 screws and replace it, easy. Hope this information can help.
- 7833 Views
Last post by ggleavitt
- 1789 Views
- 594 Views
Last post by rejaccount
- 1033 Views
- 612 Views
Last post by cjrayburn1
