This is now compound charged, the turbo feeds through the top intercooler into the supercharger (which compresses the boost out of the turbo) then from the supercharger to the front mount, this is capable of giving an easy 35psi of boost using the standard 15g turbo.JRL wrote:You're right, a VERY little videoclaymore wrote:have a little video
Is the turbo still there or is this now just a supercharged Volvo?
850 T5k
- Has thanked: 2856 times
- Been thanked: 1332 times
That is awesome. I'm sold. Please keep us abreast of updates and milestones, especially if you get it dyno'ed.
But be careful man. Driving on the wrong side of the road with all that power is doubly dangerous!
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
Curious as to where this goes...
Lol gotta say... THAT IS A HUGE HOOD SCOOP MANG!
what are the holes drilled for on the hood? are you worried about water?
scumcity14
- Year and Model: s70 t5m 1998
And all of this is being fed through an air filter (mounted in a hot engine bay) with more dirt and leaves in it than his driveway..then through the tiny stock intake flex pipe to the turbo. the charge air flows through an intercooler made of aluminum that is mounted on the top of the engine where the heat from the engine will heat the aluminum and probably negate most, if not all of the airflow cooling properties..I think the top mount isn't serving a purpose where its mounted...if you must run 2 intercoolers (?) why not the stock and then a FMIC in front of it..there it will not be heated by the engine.The concept is there..the execution and details will need sorted. just my .02
sounds like comments I'v heard a million times from people who think they know it all, all these problems are there your quite right (asuming all I'm going to do is have the car parked on the drive and not moving), I however am driving the car and can tell you that the charge coming out of the top mount is a lot colder than it ever was coming out of the original intercooler (which has an aircon radiator in front of it and a hot radiator behind it) I have been monitoring temps a long time before this modification and again, once driving the car the engine bay drops to ambient.scumcity14 wrote:And all of this is being fed through an air filter (mounted in a hot engine bay) with more dirt and leaves in it than his driveway..then through the tiny stock intake flex pipe to the turbo. the charge air flows through an intercooler made of aluminum that is mounted on the top of the engine where the heat from the engine will heat the aluminum and probably negate most, if not all of the airflow cooling properties..I think the top mount isn't serving a purpose where its mounted...if you must run 2 intercoolers (?) why not the stock and then a FMIC in front of it..there it will not be heated by the engine.The concept is there..the execution and details will need sorted. just my .02
as can be seen in this pre charger shot, I do have an air box, plus co2 cooling plus nitrous
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
IDK, it sounds like a swarm of bees in the video, or a Honda.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
- Year and Model: Lots
- Been thanked: 128 times
After seeing so many repeats of the same old configuration in everyone's Volvo this has me VERY INTERESTED and RHD too.
Can you enlighten me as to what mods were done to standard engine parts (if any) to handle the extra pressures?
- 4700 Views
Last post by tryingbe
- 670 Views
Last post by shaker_chi
- 877 Views
Last post by misha
- 1943 Views
Last post by misha
- 2704 Views
Last post by and1one1
