ABS Module??
VolvoTurbo850
- Year and Model: 1994 850 (T5)
Re: ABS Module??
Do a voltage test to see if there is a draw.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
- Has thanked: 1503 times
- Been thanked: 3817 times
Old thread alert...adding to this one rather than starting new
My 1999 T5 occasionally throws the ABS and P1550 code which clears after a few cycles. The speedo also sometimes quits when this happens. I have a business card with rpm/mph conversion on my dash o I don't get a speeding ticket as backup.
I have a ignition switch on order from IPD and will replace that to see if that clears it up, otherwise I'll get a rebuilt ABS from Matty Moo.
