When to replace the timing belt
Otto2005s60
Year and Model: S60 2005
Post by Otto2005s60 »
Hello again,
Just finished replacing the driver's side axle shaft/cv joints, struts, strut mounts and spring seats. I was going to replace the passenger axle but someone, probably the dealership I bought it from had apparently just changed out one side. I want to thank all who posted about the axle change out procedures and note that it was easier than changing the spring seats for me. Thanks to those who posted pictures.
On to my new question. I found that I have an oil leak on the front of the motor. I have not pulled the covers off and done a cleaning to determine the culprit, but it does have 123,000 miles on it. Thus my question, how long do timing belts, tensionors, and water pumps generally last on the 2.5 liter turbos? If I am looking at having to replace one seal I will probably replace them all (save the rear main, I am not a masochist), and if I am going to do that, then a new water pump, tensionors and timing belt will go on too. The leak is not bad for now, so I might live with it for a while before doing the front reseal/timing belt change out.
I appreciate anyones advice on this,
Otto
P.S.-One more question. Posts on front end problems have given me a good idea of what to expect, watch out for and replace, but I have not seen enough to get an idea of when problems start occuring with the rear suspension. Would apprciate comments on that as well.
Otto - If at first you don't succeed...skydiving is not for you!!!
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
Timing belt interval is at 105k so you are due. As you mentioned change the tensioner and idler as well, they are as likely to fail as the belt itself breaking with age. The water pump is not a high failure item, but while you're in there you might as well put a new one on. In regards to the seals, I generally don't have them changed unless they are leaking. I've never had much problem with the rear suspension on these cars, your struts obviously will be shot at some point if you keep the car long enough and I've had to change an endlink or two on the rear but basically no major issues there that I have found.
Volvos rock3
Year and Model: v70xc, 2002
Post by Volvos rock3 »
The dealer recommended 80k for the timing belt, the scheduled is 105k, I changed mine at 90k and it was pretty well worn, starting to crack, etc.
1996 850 GLT sdn (deceased)
2002 V70XC 118k
2009 S80 3.2 37k
1998 Chevrolet K1500 84k
1965 Pontiac Lemans convt
2009 Chevrolet Tahoe PPV 2x (work)
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
105K or SEVEN YEARS
randyman
Year and Model: S60 AWD 2002
Post by randyman »
Absolutely! i postponed due to things going on in life and did mine at 120,000 or so. I could have rapped the old one around twice! Don't wait!
lexluther
Year and Model: V70XC 2000
Post by lexluther »
I've checked everywhere and both dealer and independent volvo only shop said 100k or 10yrs. With that note I have 13k miles and 11 yrs on my car and belt looks fine no wear marks no discoloration etc. But why take the risk although the engine is not zero interference it can take 2-3 teeth off the alignment it will however bend valves with a belt failure. I also have rear cam seal seepage not sure whats going on in the front seals. I would change the belt its one of those piece of mind deals and if it goes wrong its goes horribly wrong pros outweighs the cons. Independent quoted me 1200 for the job but I'm sure he's way off base as 700 was the labor part and rest parts.
zooplane
Year and Model: V70 2003 N/A
Post by zooplane »
i have 97k on an 2003 v70 non turbo... time?
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
zooplane wrote:i have 97k on an 2003 v70 non turbo... time?
yes,
but will be much better if you sell the car now before this expense and get yourself the 2.5T or T5 wagon you want :D
jjaV70T
Year and Model: V70 2.4T 2003
Post by jjaV70T »
lexluther wrote:I've checked everywhere and both dealer and independent volvo only shop said 100k or 10yrs. With that note I have 13k miles and 11 yrs on my car and belt looks fine no wear marks no discoloration etc. But why take the risk although the engine is not zero interference it can take 2-3 teeth off the alignment it will however bend valves with a belt failure. I also have rear cam seal seepage not sure whats going on in the front seals. I would change the belt its one of those piece of mind deals and if it goes wrong its goes horribly wrong pros outweighs the cons. Independent quoted me 1200 for the job but I'm sure he's way off base as 700 was the labor part and rest parts.
The bearings can go bad and seize,,,or the belt can unravel..
I bought a T-Belt kit [Volvo from FCP, for 115.00,
dealer, 850, no w/p..
, I will check for bearing play, before I replace the W/P, imho..
..john
.2003, V-70,. 2.4T, 101,100K..
.1985, 245T,.sold at 280K....
.1974, 145, sold at 250K....
JRL
Post by JRL »
uh yeah!
