List your 850/S70/V70/XC70 parts failures, 1992-2000 only
Locked
What's *failed* in your 850, S70, V70, XC70, C70 (1992-2000)
Timing belt
50
2%
Top engine mount bushing
262
10%
Thermostat
152
6%
Door check strap or hinge
183
7%
ABS module
285
11%
Rear main seal
62
2%
Wheel bearing
92
4%
AC evaporator
103
4%
ETM
46
2%
Battery cable
48
2%
Any keyless entry component
129
5%
Any interior switch
210
8%
Camshaft position sensor
48
2%
Fuel pump or relay
111
4%
Heater core/ blower / resistor
183
7%
AWD's driveshaft or bevel gear
43
2%
Power antenna
156
6%
Sway bar links
146
6%
Mass airflow sensor
126
5%
Air pump
67
3%
Glovebox lock
65
3%
Head gasket
32
1%
Total votes: 2599
General Lee
Year and Model: S70, 2000
Post by General Lee »
Power locks and windows.
etanita
Year and Model: 2000 c70
Post by etanita »
turbo 2000 c70
Vernh59
Year and Model:
Post by Vernh59 »
Besides the ones listed my air conditioning compressor is going out and my powere steering pump is leaking at 235,000 miles. What a POS!!!!! :mrgreen:
Vern
'99 Volvo S70
dasapir
Year and Model: 98 S70 turbo GTL
Post by dasapir »
turbo
antenna
air pump
control arms
engine mounts
key ignition system
sun roof
heater core
trunk damper struts
rubber lines above fuel tank
'98 S70 turbo GLT
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Volvo 850 '95 Rear shock mount (fractured) @ 140K miles
jovanbrandt
Year and Model: 1999 volvo s70 GLT
Post by jovanbrandt »
i recently hit a curb in my 99 s70 and it totally messed up my front crossmember and numerous other parts,i had to replace it and my radiator just so i can drive it but i also noticed more damage like shown in the pic i added, i dont know what exactly the parts are and what needs to be fixed. i just know theres a constant oil leak
The last post would be classed an accident, not a failure.
The only failure was the competence of the driver :D
That's not a great way to welcome you to the site now is it?? LOL
Please steer clear of curbs no-one likes seeing a messed up Volvo especially a leaky one :D
I can't make out what is damaged there. Can anyone chime in?
jovanbrandt
lol i see, i just dont know where else to ask
bugeye58
Year and Model: 740 turbo wagon, 198
Post by bugeye58 »
Steering rack @175,000 mi. Left halfshaft , 189,000 mi, left headlamp circuit board @ 191,000.
Jeff
'89 740 Turbo Wagon
'95 850 GLT
1998crosscountry
Year and Model: 1998
Post by 1998crosscountry »
Hi there,
I have a 1998 V70 XC AWD Cross Coutry, with 128,000 miles, it does have being good so far but now develop a new problem, the engine management comes on some times with no reason at all, is not flashing just stays on. Over here were I live it is still cold temperatures around 6C, last Saturday it was very hot temperatures raised to 22C, and I was driving my car with the engine light management on but as soon it start being more hot the light just switch it self off for the rest of the day, it was fine.
It is this normal or not?
Another thing I did notice about this same problem is if the battery is disconnected the warning light does not come on for a few days.
Can some one please tell me watt kind of problem is this and watt is the solution.
Thank you.
Locked
