Air pump is not turning on - 1998 V70 T5
maxtegroom
- Year and Model: 1998 v70t5
no no my volvo is in the most immaculate of shape i would say 9.9/10 and everything works perfect.. so i will get this air pump turning on no matter what im just at a wall right now i have been a master tech for about 7 years and i know what i am doing and this problem just has me stumped.. this morning it was kinda quite at the shop and i heard the vent soleniod click and the valve opening and closing, its pulse width modulated, and i know that the rest of the system is working fine.. i have a modus scanner but i do not have the volvo software for it.. i was thinking that the computer is not turning the pump.. has anyone had a problem where the computer would not be turning on the air pump?? keep in mind that all i did was change the pcv system and now this is happening...
maxtegroom
one more thing i saw on i guess 850s there is a relay that looks like a cooling fan relay down by the air pump itself i didnt see that on my car the only relay like that is the actual cooling fan relay up above that fans under a little shield by the air pump valve solenoid.. is the only air pump relay i have in the "kidney" shaped fuse box second one up.. cause all those circuits and the relay tested good...
maxtegroom
ANYBODY HAVE ANYTHING ELSE PLEASE PLEASE PLEASE READ....
maxtegroom
so while trying to fix this air pump issue i broke the jb welded hose connector off the air box that goes to the air pump and i heard the beat of the exhaust thru the inlet hose for the air pump??? is the sas valve broken?? i can hear it open and close when the vacuum is applied...
maxtegroom
its very important that the pump works cause i still have a p0410 and i have to pass inspection in may...
fields 100
- Year and Model: s 60 T-5 2013
The fact that you hear exaust beat tells that the valve is OK, providing that this sound is heard only on the cold start and goes away after couple of minutes, otherwise the valve is partially or completely stuck open.
HeyNeighbor
- Year and Model: V70 2000
did you get it fixed yet?
- 1775 Views
Last post by erikv11
- 958 Views
Last post by volvo2006taj
- 36 Replies
- 5809 Views
- 454 Views
Last post by cn90
- 803 Views
Last post by Grover365
