I'm having the exact same problem with the IPD kit. The hose from the throttle body doesn't reach the IAC. It looks just like yours. They said the kit was from a company in Norway. I guess these don't fit our cars after all.
I would assume that the Samco kit does fit, but it's hard to tell from internet pictures. Therefore I'm going to return this kit and order the standard replacements.
Anyone Buy Intercooler Silicone Hoses?
Silicone Intercooler Hoses
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
Same vendor to both IPD and FCP?
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
Alecw81
- Year and Model: S70 GLT 1998
I've been trying to install my silicone hoses from FCP today (the inexpensive ones, not the SAMCOs).
I was able to get the small ring onto the top of the turbo, but have not been able to get the OTE pipe into the other end of it.
I was able to install the throttle body/IAC hose.
I was able to install the upper intercooler hose , and connect the plastic extension to the throttle body/IAC hose.
I have been completely unable to even get close to fitting the lower intercooler hose over the lower metal pipe, and haven't even tried the hose that links the OTE and lower metal pipe.
Does anyone have any tricks for these?
I really don't want to throw in the towel and put the remaining OEM ones back on, and I can't re-use the top coupler (turbo to OTE pipe) as it was torn when I inspected it before removal... HELP.
Alecw81
And now I can't wrangle the lower pipe into position to hook up to the bottom intercooler port and the OTE pipe.
Everything else is together.
Whomever decided to make these hoses ID about 4mm too small needs to be dragged down the street and shot.
Alecw81
Finally got Everything on using silicone spray, and cutting 45degree angles on the lips of the "s" hose. The 90degree was ok with just silicone, and all the rest took lots of force and soapy water and a hair dryer.
When I first got the hoses I soaked them in boiling water, I don't think it helped much.
kcjones
- Year and Model: 1997 855 GLT 200k :)
So after all that, should I bother ordering some? It sounds like the manufacturer knows that they're skewed, but doesn't want to do anything about it.
But for 5 bucks over OEM, it hurts not to have silicone.
Did they even test fit this product on ONE car before it hit the market?
- kcodyjr
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 17 times
- Been thanked: 23 times
Just picked the 97 GLT up from the indy who, among other things, installed Samco intercooler hoses for me.
"Pain in the cock" was just about the most polite thing he had to say about them.
I suspect they're intended to be hellishly tight so they don't blow off.
He found a shoe-horn did the job, and that a second set of hands also helps - one to push the pieces together, the other to jam the shoehorn in and pry the hose outward.
5 others that came and went
- 34 Replies
- 11060 Views
Last post by theWIFES_S70
- 13 Replies
- 3039 Views
- 1184 Views
- 3054 Views
Last post by wizechatmgr
- 10 Replies
- 10282 Views
Last post by JDS60R
