USE OEM ONLY for these:
elchopperfreak
Year and Model: S70 T5 1999
Post by elchopperfreak »
Dig this thread.
Would be interesting to find who manufactures the OEM volvo parts, for example in Harleys theres a vast list of who makes what for them, and you can buy the same exact part from the manufacturer for a lot less money.
peacock
Year and Model: S70 T5 SE 1998
Post by peacock »
WHEEL BEARINGS
1998 S70 T5 SE 214,001
1999 v70R 126,000
98V70T5
Year and Model: V70 T5 1998
Post by 98V70T5 »
MUST USE OEM FOR: THERMOSTATS, TIMING BELT COMPONENTS (BELT, PULLEY, TENSIONER), SERP BELTS, WATER PUMPS
Schmitty
Year and Model: 1995 Volvo 850 turbo
Post by Schmitty »
Everything! Keep your Volvo a Volvo! :D
1995 850 Turbo -- 118K miles
91 Octane Premium + 3oz. Lucas Oil
Synthetic Mobil1 5W30
K&N Air Filter
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Oil filter is important - I used a Fram once since I didn't have a Mann on-hand, and it made terrible noises on start-up. Anything with a check valve built in works OK. If you've got a 1999 or 2000 with the canister housing where you only replace the filter insert, it really doesn't matter what you use.
+1 on the sensors - they are very picky.
Wheel bearings - FAG are a good alternative. They actually make the bearing for the Volvo brand.
Do yourself a favor and don't buy the PCV "kit". It's a worthless piece of crap. I wish I'd known that at the time.
I've never used OEM spark plugs - they're too expensive. I've always gone with either Bosch Coppers or Autolite Platinum. Both seem to run fine in my T5.
SUSPENSION PARTS - OEM or IPD HD. From a longevity standpoint, nothing else stands up. Some have said good things about the aftermarket FCP Groton control arms, but avoid ScanTech. Looking back at maintenance records, I've got over 90K on my OEM control arms - the steering stops are now broken on both of them, but the ball joints are still in great shape, which is saying something considering the shape of our roads here/how I drive.
Engine mounts - OEM is the way to go unless you like rough idle.
I would not dare cheaping out on anything in the timing belt compartment. Or the thermostat.
RUBBER HOSES - OEM ONLY! The aftermarket alternatives to any of the hoses under the hood of these are pure garbage (at best).
I have a Nissens radiator, and no complaints yet. Behr is also a good alternative to the OEM Valeo radiator - they make good stuff.
Some have said that the aftermarket FCP heater core is smelly. The OEM one is about $30 more.
For some things, like brakes, there are many very good aftermarket alternatives that are in fact better than the OEM pads/rotors (the Volvo rotors warp easily and the brakes are dusty). Axles - R-axles is the way to go. I had an OEM Volvo one that failed again within 30,000 miles. And never use Scan Tech anything. Or URO anything, if at all possible. I have many complaints with them myself.
'98 S70 T5
2016 Chevy Cruze Premier
urbex
Year and Model: 1994 855 T5R clone
Post by urbex »
jblackburn wrote: Some have said that the aftermarket FCP heater core is smelly. The OEM one is about $30 more.
I've found that my local dealer (Sanderson Ford/Lincoln/Mercury/Volvo) here in Phoenix has always been no more than $10 more than what FCP or Autohaus sells stuff for everything that I've bought so far, and usually is within a few bucks of the online stuff. Plus they've just about everything in stock already, vs. having to wait to have it shipped to me. I've been at the parts counter quite a bit over the past few weeks, lol.
Been thanked: 504 times
Post by cn90 »
The whole idea of this thread is how to get the "most bang for the bucks"....so by knowing the original maker of a particular part, you save money by buying that particular brand!
98V70T5 wrote:MUST USE OEM FOR: THERMOSTATS, TIMING BELT COMPONENTS (BELT, PULLEY, TENSIONER), SERP BELTS, WATER PUMPS
Volvo Tstat made by Wahler.
Timing Belt, Serp Belt are made by Conti-Tech.
Tensioner made by Aisin
Pulleys: INA is a good brand.
Water Pump: OEM is Aisin, alternative is Hepu (a very good brand).
peacock wrote:WHEEL BEARINGS
Wheel Bearing is made by F.A.G.
A very good alternative is SKF.
Post by cn90 »
Another issue that will come up for many of you guys is: BRAKE HOSES which will crack after 10-14 years/100K miles.
This is a critical safety item.
Volvo Brake Hose is $35-40/each at dealer. But no need to buy Volvo brake hoses!
ATE is the OEM, I paid $13/each online.
I wrote the whole DIY for hydraulic system rebuild here:
DIY: 98 V70 Brake Hydraulic Overhaul (Hoses, Seals, Parking)
https://www.matthewsvolvosite.com/forums ... =1&t=37721
gilhuly
Year and Model: 98 V70 GLT
Post by gilhuly »
It must be a real pleasure to not have to carry the burden of critical thought around all the time.
Schmitty wrote:Everything! Keep your Volvo a Volvo! :D
1998 V70 GLT, 15G swap
Fairfield, CT
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I'm really liking the way this thread is heading and would be a valuable tool for the newcomer (and experienced) home mechanic. Gained some really valuable info thanks guys!! (and girls??)
