just replaced cat and still misfiring
I have a Volvo 2002 S40 with 92,000 miles on it. i just replaced the CAT and its still misfiring. The spark plugs are good and I am unsure of what else could be the problem. The code for the CAT keeps coming up. Doe anyone have any ideas. I honestly don't know anything about cars.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
The cat converter usually wouldn't be causing misfires. You ignition coils could be bad (more likely), you could have a problem with your front oxygen sensor, or something else.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
i don't know the code right now but i can get it tomorrow from my mechanic but hes at a loss of what its is and hes not familiar with volvo. but from what ive read here and there seems like the s40 is has a lot of issues.
he said hes done that coils are fine. new spark plugs. Everything was fine with the car then i got a check engine lite for the cat thats when i felt a chug in the engine when i accelerated fast, other than that it ran perfect except i noticed instead of 300 miles + to a tank i got 200 or less took it in asap switched cat and it hasn't even left the shop because right after the new cat it gave the cyl 3 miss fire. i dk everything that been done because i know absolutely nothing about cars but i know hes tried almost everything he can think of.
Bandit7311
- Year and Model: V40 1998 2,0T
Ignition coils are a big issue on those models.
If unburned gasoline comes to the cat it will be detected and this unburned fuel can go there because the ignition was not working correctly.
Please look at the ignition coils closely for cracks and / or just replace the ignition coil of cylinder 2+3 (the middle cylinders run over one ignition coil)
Solong
B
Solong
B
im the tech working on the s40 volvo, swoped coils stays on cyl. 3, swaped injectors stays on cyl. 3, checked flywheel pulse wheel windows checked good mass air sensor good,checked timing belt checked good, check compression on all cyl. 175psi, check leakdown on all cyl. check good replaced spark plugs STILL MISFIRES ON CYL. 3 CODE P0303 ONLY UNDER LOAD!!!!! PLEASE HELP ME SO I CAN SALE THIS CAR
- 2241 Views
Last post by MoVolvos
- 5986 Views
Last post by chrism
- 23 Replies
- 3968 Views
Last post by warmblood58
- 11 Replies
- 2522 Views
Last post by mbaskette
- 6355 Views
Last post by RB3
