01 V70 2.4T Oil Leak since spark plug change?
brandonbeach14
- Year and Model: 2.4T V70, 2001
I changed the plugs on my V70 yesterday and I noticed what might be a leak on the pass. side side this morning. It looks like it's coming on the back side of the engine and dripping a small amount on suspension under the CV joint. Maybe over tightened the plugs? There was just a little oil on the #4 plug when I removed it, but that was it. In the last week I have also did a Seafoam treatment to the intake, Amsoil to the engine, changed the oil with Penzoil Plat. It wasn't leaking oil prior and the oil was changed on Thursday. There wasn't any pooling of oil under the top cover or on the front side of the engine. It also isn't using an oil. Any ideas?
Thanks
JetMechGAC
- Year and Model: V70 T5M, 2001
When was the last pcv service done? You might have moved around some sludge buildup in the system with the seafoam treatment and now it is clogged. If it is on the passenger side leaking onto the cv joint (I bet also onto the motor mount also) then you might have a leak comig from the cam and crank seals on that side. Pull the timing cover back and inspect in that area for the leak.
brandonbeach14
After tracing the leak back up the engine and after taking the cover over the plugs off it appears to be leaking at the oil filler neck or cap. The entire area was filled with oil and was running down the back of both sides of the engine. I have already ordered a new cap, but can the neck leak too? Thanks
- kcodyjr
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 17 times
- Been thanked: 23 times
It's advisable to change that oil cap seal with each oil change.
5 others that came and went
brandonbeach14
Will do thanks, Ever see a leak at the base of the neck? I figure it's most likely collecting there from above where the cap is, but I am covering all my bases.
JetMechGAC
You should replace the filler cap gasket with IPD's HD gasket. I don't know why but for some reason these cars like to leak oil from the filler neck. I wouldn't think that you would have a leak at the base of the neck though.
- 3119 Views
Last post by Roger_850T
- 1456 Views
Last post by amblerman
- 1968 Views
- 844 Views
Last post by oragex
- 3930 Views
