Hello all and Happy 2006.
1993 Volvo 850, (nonturbo), manual, 135000 miles in Atlanta, GA.
Car burns oil; about a quart every 5000 miles.
3 problems (for now):
1. Clutch has begun making a slight noise every time it gets pushed in. Still lets me shift etc, just makes that icky sound. Any idea on whats wrong and how much it should cost me to get fixed?
2. RPM's will run up without there being a increase in speed. Gotten so bad that it has trouble taking off on hills etc. Will start SLOOOOWLY then after alittle while it "catches" and gets up into speed. Same problem happens in hills while driving where I have to downshift and rev the rpm's to not loose speed. Compression problem? Manifold/valves? Price?
3. I suspect there being a exhaust leak in the manifold or gaskets. Will sometimes give a small bang underneath the car just after shifting. Ideas? Price?
Any and all suggestions/answers GREATLY appreciated.
Thanks and happy new year.
Erik
93 850 Lacks Power & Needs Clutch, Topic is solved
2000 V70 Becomes Test Mule for Parts
yeagermeister
- Year and Model:
All are indicators that you need a new clutch. The sound it's making is likely the disc slipping against the plate, and then possibly again once they have finally stopped slipping. This is also why the RPMs go up without an increase in speed- hills, starts, etc.. all put more of a load on the clutch, which increases the likelihood of slippage.
Norseman wrote:Hello all and Happy 2006.
Erik
(the other) sean
'94 855 5-speed
'02 lifted Nissan XTERRA
'94 855 5-speed
- Has thanked: 2664 times
- Been thanked: 1256 times
Agree with yeagermeister. All the symptoms sound just like when the clutch wore out on an 81 Horizon I owned.
yeagermeister
- Year and Model:
You owned an '81 Horizon? That's embarrassing, man! Don't out yourself like that!
My '87 Suzuki Samurai did the same thing- going up a hill at 55 in 5th, suddenly doing 35 and taching 6k...
matthew1 wrote:Agree with yeagermeister. All the symptoms sound just like when the clutch wore out on an 81 Horizon I owned.
(the other) sean
'94 855 5-speed
'94 855 5-speed
... in '86yeagermeister wrote:You owned an '81 Horizon? That's embarrassing, man! Don't out yourself like that!
