Headlight Lens Replacement 1998 v70
jbo6924
Year and Model: 1998 v70 t5
Post by jbo6924 »
Anyone ever replace a Headlight Lens on the above?
Replacing one this week, any insights would be great.
Jim :mrgreen:
Juan62
Year and Model: S70 T-5M 1998
Post by Juan62 »
For 98 S-70 T5-M: Remove the metal clips (carefully) surrounding the glass lens. Next, open and remove the bulb covers (round) and disconnect the electrical wiring for (both head light and hi-beam)...leave the bulbs intact (inside the headlight assembly. Next, locate three bolts holding the headlight assembly (mine has three bolt...two one one side, and one on the other). Do not adjust any angles of the headlight (were the leveler or mercury sits). Remove the entire headlight assemly towards the front bumper (you). Gently remove the glass, and remove the old glass (lens) and reverse the operation. About 30-40 minutes for first timers. Your done!
98 S70 T5-M Brick for life
anjill182
Year and Model: 98 XC,98 AWD, 95 T5R
Post by anjill182 »
Remove the whole assembly then remove the metal clips!
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
anjill182 wrote:Remove the whole assembly then remove the metal clips!
Absolutely! When I changed mine, the first step was removing both headlights.
Popping the clips on the bench was a piece of cake once they were out.
And I left the lamp covers in place and just unplugged the
connector for the entire headlight assembly. Much simpler.
And absolutely, positively resist the urge to touch ANYTHING behind the lens.
Oils from your hands will fry the lamps and the front coated silvering on the
reflector is extremely delicate and will scratch if you even breathe hard on it .
The cheap, Scancrap E-code lense's that I installed came with a long piece of rubber
to replace the complete "loop" of the original sealing gasket. Keep the original...
The other one will leave a gap, allowing moisture into the headlight.
Like you read above, this shouldn't take more than an hour.
Another exciting Volvo DIY project!
Have Fun! :wink:
jbo6924
Post by jbo6924 »
Thanks for the Tutorial, much appreciated.
Jim
peacock
Year and Model: S70 T5 SE 1998
Post by peacock »
i like the original clips as well. i reaplced only about half of them when i did my lenses. Great way to restore the front of the car.
1998 S70 T5 SE 214,001
1999 v70R 126,000
Been thanked: 471 times
Post by cn90 »
Driver side lens is cracked.
I understand OEM is Hella.
My choices are:
- Nordic lens from eeuroparts $60.
- Hella lens from eeuroparts $100.
- Used assembly (the entire HL assembly) from ebay $50.
Anyone here used Nordic before?
KlubMarcus
Year and Model: V70 XC, 1998
Post by KlubMarcus »
Just replaced one my headlight lenses. Bought a no-name brand because the right hand lens cracked while driving through a storm system, same one that spawned all those tornadoes!
I definitely agree with re-using the factory gasket and clips, and disconnecting the wiring harness for the entire headlight assembly to take it all out at once. The hardest part was getting a socket head on the bolt next to the turn signal.
:o The beater just won't die! So we're clawing our way back to Stage 0.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
cn90 wrote:Driver side lens is cracked.
My choices are:
Oem would be Hella & Bosch.
I would use used Oem assembly or a new Hella lens.
Aftermarket lenses have a slightly different glass pattern from OEM ones and the light output would be weaker than with oem.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
djohnk
Year and Model: V70XC 1998
Post by djohnk »
When I replaced my lenses I cleaned the reflective surface and ruined the headlights. I ended up using spray adhesive and tinfoil to get by.
In the end up buying just the lens was a waste of money, because now I have to purchase the whole headlight which comes with a lens.
What I am trying to say is if your headlights are old you may just want to purchase the whole module.
1998 V70XC
